apparently last night as soon as it hit 10 the police shut down the area and started defecting everyone, a guy at work only just got away without a defect by legging it (his car is about 4-5cm of the ground.. literally).
if your going to bring your car dont park anywhere near lonsdale street (or whatever that main street is called) or leave before 10pm
personally im going to go stealth in the 'rago.. anyone want a lift :)
Edited by nerm
https://www.sau.com.au/forums/topic/302747-summernats/#findComment-5022226
Really?
Frink and I got in there at about 9:45, we drove my car in there and parked right in the middle next to the Lonsdale St. car wash and sat there until 10:30 and saw a fair few cars, but not heaps. Cops stopped a few people but we didn't see any big shutdown at 10pm, nor mass defects.
https://www.sau.com.au/forums/topic/302747-summernats/#findComment-5023686
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
