I would go for a high flow panel filter from K&N or Apexi. You can buy the K&N filter from Autobarn and the Apexi one most i think some traders on the forum sell.
In terms of the pod filter, again I would go for a K&N or Apexi. Depending on which state you're in, not sure if this would be a defect modification for you. Studies have shown the Apexi produces most power with the best filtration with the K&N coming in second best.
Cheers
Pod filters are a waste of time and don't gain any real performance over a high quality panel filter in stock airbox.
You just need to look at the Mines R34 GTR or any Mines car for that matter he uses panel in stock air box.
Go the k&N panel.... :rant:
4 an N/A +1 on keeping the stock airbox with a hi flo panel filter... really not worth it unless ur after hektic induction noise lol, u will need it fully encolsed, CAI, it fully mounted etc 2 much effort lol
I honestly don't hear any noise difference on an NA motor. Unless the hood is open and I'm sticking my head in to a get good look, I can't hear it.
On a turbo set up, it's pretty obvious.
on some NA cars it's very obvious though. i have had a pod on 3 6 cylinder cars (falcon, commodore and magna) and the falcon and magna it made a massive difference to the intake noise (sounded throaty) but the commodore it didn't do a thing.
A pod will suck hot air from the engine bay if you dont have a shroud for it and some form of cold air intake.
Go the quality panel filter
Hot air = fail
Yes should have explained self better, was thinking of a Pod inside a custom airbox
Go the k&N panel.... :D
Thanks
Thanks, was just asking as these things are so underpowered, not that I want it going to hard for my leaner daughter.
Just feels so slow compared to my 400rwkw+ BA Turbo.
Will just go with a K&N Panel Filter and look into improving the exhaust.
I went with the Apexi power intake and decided to make my own heatsheild, still not finished the sheild gotta make it look nice.
Cost me about $30 to make it, makes a big difference if its shielded or not
Thats what I was thinking, Thanks
i'd be worried if it didn't.....
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
