  • Replies 66
haha i wish it was that easy, i should have explained it better. whatever parts he has spare. which all seem to be upgrades on my current system.
having an ex drifter for a mate is a bonus.
doesnt help him having expensive taste in alcohol though haha
before you go upgrading your injectors or turbo you will need an aftermarket engine management system lol....so investing in a PFC or a haltec or what ever is a good idea....some people even get a RB20 ECU remapped to suit a RB25....or they get a VG30 ECU remapped to suit a RB25...speak to Jeff in regards to that as he is the man with the know how
yeah someone else has reccomended the vg30 ECU path, and i think my mate has one laying around or i may be mistaken. cheers for the help guys
not a bad idea but i would go with the Power FC if i were you mate....got on in the car and its damn brilliant....works a treat and most tuners love them
if you dont have a hand control for the pfc, then the cop would need to pull off the kick panel and know what a "Power FC" is.
Or you can put the standard computer cover on the PFC, then Regency probably wont even know. I know someone who has passed Regency with one :rant:
The PowerFC only supports manual cars (excluding Toyota). It will work on an automatic car however it will not handle gear changes and simply keep the throttle nailed during a gear change. This will result in jerky gear changes and stress placed on the gearbox. The factory ECU during a gear change will communicate with the auto box and drop timing, ignition to ensure a smooth change. For those wishing to use PowerFC with auto you should consider a mechanical auto gearbox instead of an electronic. The PowerFC should work fine with a mechanical gearbox such as power glide, transbreak etc.
This is because the mainstream ECU's in Nissan etc rely on the main cars' ECU for gear logic change control and functions. Cars such as the Toyota have a seperate ECU for the gearbox change logic and control so it's not affected. Apexi chose not to port the Automatic gearbox logic code (as its very long and complex) into the PowerFC because I suspect they found its simply not worth it & too complicated. You can buy an Automatic PowerFC for a Toyota Chaser for example and it has auto logic control under SETTING, you can set the shiftmap, ramp up speeds etc as it has the code to interact with the Toyota AUTO ECU that is seperate to the main ecu. So in summary - Auto PowerFC's exist & work but only for Toyota. We have seen quiet a few Auto R33 Skylines with manual PowerFCs - some report they work fine etc and there is no difference - do so at your own risk.
Thanx for the info damo is there anything you would reccomend to run on the auto as a replacement for a pfc or is it pretty much jus buy a manual car lmao??
Tis what I did! :rant:
If keeping the auto ... an Apexi SAFC and SITC can do the job nicely.
:rant:
Ruby how much did it cost you to get the manual put in and who did it??
The safc and sitc are they 2 diff things if so which would you reccomend?
I fitted the box myself with Luke's help. Took our time and ensured we did it right and it went in without a problem.
The SAFC (super air flow controller) allows you to control fuel ratios (to a limit) and the SITC (super ignition timing controller) allows you to make timing changes. If you can only get one, get the SAFC first as sorting out your fueling issues should come first. Tho the SITC is cheaper, but harder to come by.
Thank-a-you Damoo and Ruby will need to pm u n find out sum info about the manual conversion parts prices etc considering doing it :)
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
