All items located in Cairns, QLD. PLease contact me via e-mail ([email protected]) as keeping up with pm's with the only 1 pm every 5 mins rule makes it very hard. I can also be contacted on 0437838032.
Item: Tomei Pon Cams
Condition: Brand new, in original packaging.
Price: $700
Item: Tomei Cam Gears
Price: $300
Item: Tomei Cam Cap Studs
Price: $300
Item: Tomei Valve Springs
Price: $500
Item: Tomei Sump Baffel
Condition: Brand new.
Price: $350
Item: Tomei Metal Gasket Kit
Price: $600
Item: Adjustable R32 GT-R Rear Camber Arms
Price: $250
Item: Mines Style cam cover baffles
Price: $150
Item: Blue alloy alternator pulley
Price: $40
Item: Oil Cooler Kit, Filter relocation
Condition: Used
Price: $200
Item: c's Short Shifter
Condition: Used
Price: $250
Item: Nismo Oil Cap
Price: $100
Item: Nismo Radiator Cap
Price: $100
Item: Greddy Turbo Timer
Condition: Used
Price: $50
Item: Standard Igniter
Condition: Used
Price: $50
Item: Nissan oil pump gasket
Price: $20
Item: Gates Timing belt
Price: $80
Item: Accel coils x 3
Price: $100
Item: Greddy Dual Gauge Pod
Price: $80
Item: ARP Head Stud Kit
Price: $500
Just to be clear. From now on anything purchased off me that is sent via post, i'm not responsible for what happens to it after i drop it off at the post office. Poastage will be the buyers risk otherwise i may as well just dump all the parts in the bin.
Cheers,
Rob
After much sweating the cam gears finally arrived this morning. That's 10 working days or twice the stated delivery time from Austrlia Post. Worth considering Express or Registered next time.
Packaging good and exactly as described.
Thanks.
What brand is the oil cooler fittings and relocation kit Earls, speedflow etc?
Not 100% of the details of the kit as I did not buy it new. The pics show exactly what is included. Oil cooler is sold pending payment.
Cheers,
Rob
haha those radiator caps are $75 brand new from just jap
Right you are. Radiator Cap is now up for grabs @ $70. But the oil cap has increased to $140. Thank you for pointing out the value of these items as I was unsure.
Cheers,
Rob
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
