Hi all. So I've had a bit of a look around on the site and I think I've worked some stuff out. But still have a few Q's.
Q1. Does the Stag share all Suspension Arms and Bushes with the 33GTR or just some of the bushes?
Q2. I've heard that there is not much gain from fitting a new Front Swaybar so I was just gona get the rear (probs Whiteline). True/False?
Q3. I was just gona use Sydneykids Part Numbers from his Group Buy. These should still be correct shouldnt they?
I did a search of the part numbers he used on the Whiteline website and they come up so assume they will still be fine.
I'll be going into a few suspension places on the weekend and getting a few quotes etc. But I just wanted some thing to go in with. Cause as we all know their gona go "It's a What" :)
< As you can see its a RS Four S.
Thanks to all in advance.
I will let you all know what the suspension places say.
Mattye
https://www.sau.com.au/forums/topic/303024-suspention-bushes-etc/
True for me. I bought the rear one and it made a huge difference. Put the front one on a few months later but I didn't notice any significant improvement. Other people's experience may be different.
Q1. Im in the same boat as you mate :) No idea
Q2. You have the stockie on? it is after all just a length of metal, I like the front one on if for nothing else but fighting the torque monster.
Get a rear one though, it makes a huge difference
RS4S has a larger rear swaybar (24mm hollow) so the upgrade to the whiteline 24mm solid bar isn't as big a jump as the auto versions. The increase in rate is something like 70% (from memory) from hollow to solid bar. It doesn't make a huge difference like on the autos.
I am having a senior moment regarding the change in front bars.
SK's part numbers should be fine, Use tein s-tech springs. I am running 24mm swaybars front and rear, feels nicely balanced, order shocks from heasmans sydney and the rest of the stuff locally, get the swaybars from SELBY as that is the company SK used to get them made by.
I upgraded my rear sway bar with a White Line item... had that flimsy 19mm hollow thing now to a 24mm solid. WORLD of difference. Handles like a Sedan :happy:
One thing I did note when ordering, ALL GTR bars are the same. If you check BOTH Selby and White Line sites ALL the GTRs have the same part numbers/options. I also cross referenced the Stagea listing on the Selby site, same numbers!
For what ever reason why some one would, you could bolt up a solid 27mm item. As the Skylines also share
the same design as their GTS / GTT counter parts.
front and rear bars made a huge difference for me but I've got a S1 Auto. You don't even have to really replace the springs straight away if you don't want to. The standard rates are quite good as it is and a little more comfortable as well. Depends if you planning on lowering it a lot or just a bit. You can still lower the car with the stock springs as your moving the lower spring seat. Order the bilsteins from heasmans and get them to machine extra circlip grooves in so you have some more height settings to play with, get the bushes from whiteline and and bars from selby. You should be able to order all the parts yourself and then just take them into which ever shop you choose to install the gear for you. But if you do plan on changin the springs as someone else said the tein s-tech springs seem to be quite popular. Might be quicker than getting whiteline to make some up.
Hey Guys probs should have said that I already have full adjustable coilovers all round. Its already lowered and quite a hard ride. So i'm only lookin at gettin bushes and swaybar. Hopfully if putting a new rear bar on it will stiffen up the rear enough so i can soften the suspension up a tad.
Out of interest, what Coilovers are you running?
Im running 'Super Flex Wagon by Tien' direct out of Japan (not Aus specs) with 6kg springs.
I personally wasnt very impressed, but the new rear sway bar brought the bar up that much
more to make me satisfied. Although, I wouldnt mind it a little bit stiffer :D
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
