Since owning this car, I have had it to the tuners for some quick rework to get it going.
The air con (compressor, condensor, drier, piping etc etc) was removed, Mines ECU removed, Sump & Oil pickup replaced as the items fitted looked like they had a head on with Oolaroo. Pod filter was relocated to under the n/s/f guard (yes I know all about the dust issue when going bush, but I have 6 of various types) and the ECU replaced with an a/mkt Adaptronics unit.
Cheers, D
Now new brakes have been fitted to the rear, (Bendix Race Road Track) 8" wheels with 245/45 x 16 semi slicks, have welded the rust in the spare wheel well & both front strut towers. Replaced the tail lights with Aussie delivered S2 MR30 style, to save possible damage to a set of JDM hotplates.
Cheers, D
The plans!
New custom designed front & rear sway bars and springs on JIC Coilovers on all 4 corners, BNR32 GTR front brakes, Upgrade turbo from Billet turbo in Queensland, 14mm O'ring fuel rail & 770cc injectors to go with E85. Repositioning the half cage and drivers seat so that my fat ass will fit better. SAAS reclineable or fixed race seat & Willans 3" 6 point harness.
And then see how it goes from there.
After the panel repairs have been done, I'm at a loss as to what colour I should paint the front, as o/s door, o/s/f guard & bonnet will be replaced, I'm going to paint everything from doors forward.
Any suggestions?????
Yellow for exact opposite contrast, Red or Blue or what???????? as it will probably be too hard to match the purple accurately.
Cheers, D
white bro.. white... :)
Good luck with it though man, its all about personal preference.. personally i think a white car with black/dark coloured TE37's looks amazing.. youv already got the dark wheels so it will be an easy change... howeverits all upto you.. make your car loook the way YOU want, then just tell other people that dont like it to get fcuked.. :)
either way keep us updated bro, looks to be a good starting point...
Edited by iadore4door34s
I already have an KHR30 that's 002 white/028 grey, but all white looks very bland in the flesh, as I have seen quite a few.
Cheers, D
I had an Alfa go past me the other day, on my way home from up the coast and it was a very bright golden yellow (not portorecan gold), so I think it's going to be this & purple. A stark contrast I know, but very showy lol
Cheers, D
  • 1 month later...
I have always been a fan of DR30's, (Ironmask only). Now that I have one of my own, even a bigger fan. I love the white, it's a very cool colour.
Most of the DR's I have seen on here have strut braces, yet mine doesn't have one? And mine is a little bit unique.
Anyone know where I can get some tail lights, you got some D?
Mrs Cazz...
VERY jealous.
the hotplate tail lights are very hard to find in a condition to suit your epic DR, they do pop up on yaho auctions in japland, perhaps contact import monster. the do also cost an arm anda leg, i have seen ppl pay up to $400 for a good set!
i guess they are the equivalent of the 'projectors' that you R31 lovers jump on over at r31forum...
Would you consider making a separat intro thread to introduce this beast to the rest of it?? i can see its NOT the strongarm bastardisation model... phew!
I probably should make a thread about the car, and the drama's we had getting it to Phillip Island in time for the Historics.
I can't tell you what a buzz it is to have this car, and to be able to look at it every day.
Gavin's is a nice car, and sounds fantastic. He didn't modify it though, it was like that when he got it. He is currently in the process of bringing it back, and hopefully it will begin to make some appearances.
Which section should I start my thread in Mag86? Any Clues?
Just start new topic on the classic skylines main page and we can drool from there!
Gavins car is still a ripper to me, really needed some TLC to get it back to 'original' state
sorry for the rambling, im vegetated for a few days from major surgery
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
