  • Replies 71
Dont take this the wrong way, but 160k car, $80 stands, ive seen them break
I certainly wouldn't creep under a 1800kg (less 4 wheels!) car standing on 4 matchsticks.
That is exactly how my wife became an orphan at 8 months.
Sorry mate, you should think of your beautiful son, it's not worth the risk!
Edited by GT-Ricer
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5028993
I already mentioned you should use the floorjack as a backup on the front or back. What kills people in this situation is... no backup / SINGLE point of failure. 100% of the time.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5029107
Good luck with the project!!!
What are your reasons in choice of pads? Endless, Project Mu, Ferodo, etc...
I am going with AP rotors and some Hawk pads. No great science/research on my part i am just going on a recommendation from a friend who is around brakes + race cars as his job. See how it goes i guess.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5029109
Nice!
Let us know the result in the difference of the pads and rotors, stock to aftermarket.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5029955
Duncan your a brave man to be tackling this project on those stands even with a floor jack as a safety!! Good on you dude.
Ive done the AP J hook rotors, Carbotek 12 (yeah they squeal like a bitch) and Stillen braided lines and now the braking is simply amazing. The pedal has so much bite that it just hauls the car down from 200+ to 50 in a couple of seconds. If you have a spare $300 get some stillen braided lines cause when i compare my brakes to 09 GTR who has the similar set up my pedal is def stronger which would be good for your sprints.
Edited by White 35
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5032822
Duncan you have inspired me to harden up and screw the nissan warranty in view of some track work this year
I think it's great guys getting into the track work and basic maintenance themselves :thumbsup:
this thread got me thinking what I would do when I have a tool around under the car next month
I have on order some 5T truck jack stands (pin not ratchet) for work with the wheels off and some wooden blocks for under the wheels
similar to below for whilst working under the car. will let you know how I go when i get my shite together
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5034117
ok so tonight whilst the car is up on stands i thought i should get the carbon air intake installed, sometimes i wonder why i get into doing these things!
but here we go......... (better be worth it)
Martin where is my updated tune! lol.
Edited by LSX-438
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5035360
Dunc,
Hats off to you mate, it is at this point I would have another kidney tray with a whole range of nuts and bolts that are left over and I am not sure where they go.
Thanks Gibbo!
Not finished though! still got a bit to get through before the first round this sunday, going to tackle these tonight...
Yes, have a stripped stud or two AGAIN as well :( plus new j-jooks and pads
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5036588
Some of the bolts and plastic clips are getting a bit worn, so i had to source some (for the various covers atc under the car) thought i better do it whilst they are all off the car now. This is what seems to work (see pics also):
M8 x 16mm
M6 x 25mm
I picked up some high tensile ones as that is all i could find, however i am sure you can get some regular ones cheaper. The bolts are about $4~$5 for a box or 5 or 10. I noticed some of the OEM bolt heads were a bit scratched up and i couldnt use the socket on them (too damaged) so perhaps the high tensile ones wont disentegrate so easily? i dunno we'll see.
I sourced the bolts from Supercheap (i guess you can get them almost anywhere) and the plastic clips (not sure what they are called!) from JustJap in Sydney.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5036611
Because jack stands just brake everyday and all 4 fail at the same time?
You can't be serious.
I had a bunch of dramas today, snapped caliper bolt!!
How'd you manage that, did the jackstand break on it?
Edited by GHOSTrun
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5038690
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
