  • Replies 124
  • 1 month later...
Hey
I was reading ur answer for this not fitting rb25det neo motor, I was wondering why it doesn't fit.
Cheers
Rob
Hey
Cheers
Rob
Hey Rob!
The NEO's have a different engine block set-up, the bolt pattern does not match so extensive modifications would be required.
Cheers,
Brendan
(VM)
  • 1 month later...
Just letting you know that these WILL fit a neo motor. My setup at the moment is an rb25de+t neo using an r33 ecu and running an r33 s1 intake manifold to retain sensors for ecu.
The only thing that's different is you need to pull out one stud for the head and replace with a longer one. I did all the work myself and haven't had a single problem.
Hey!
Thanks for the information, I am only going off what customers have noted however I do know that many have used these on the NEO's with modifications.
Do you have any images of your set-up?
  • 2 months later...
  • 1 month later...
Hi there could you pm me with a price for a raw cast plenum with adapter for an r33 rb25det. Also do these work with the standard fuel rail? Cheers!
Hey,
Will do so now, yep original fuel rail will go straight on no problem.
- Brendan
Hey mate,
Does the plenum take all sensors that were on the stock one? IAC/AAC, vacuum lines etc.
Can you pm me a price for the plain cast finish with stock throttle body adapter to 2750 please
Thanks
Hey mate,
Thanks
Hi,
Yes mate, takes all the original sensors mate! No mods required with this one.
Will PM you now.
- Brendan
Could u please pm me a price for a raw cast aluminium plenum to suit standard throttle r33 rb25det. Thanks bud!
On it's way....
  • 3 months later...
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
