More Pics from SAU Christmas Beachside Cruise/BBQ - 21/12/03
Hey all,
You may have seen me walking around with a large camera - unfortunately my lack of experience with it and the conditions ruined a lot of my shots. :D I did manage to salvage some however...
Sorry about the bias to one car in particular, but can you blame me?
-Greg
nice pics, love the definition that camera gives... got some high rez images u can chuck on CD?
What model camera was that n what lenses were you using?
looked like a digital EOS or a Fuji Digital SLR
I used a Nikon F5 35mm SLR with a Nikkor 24-120 f/3.5 Lens. All shots were spot metered (accidentally!) and captured on Kodak E100VS slide film.
Slides were scanned in to Photoshop for minor cleaning/optimisation on an Epson Perfection 3200 scanner.
top 1 mate..... I've always loved 35mm SLR cameras... that spot metering helps to bring out the contrasts in the picture... sometimes could be better than using matrix metering which just "averages" everything in the viewfinder... in this example, you've done it well...
hmm i think i'll ring my mates at canon n tell em what they need to include in the next ixus :D I'm really amazed how clear the macro shots came out.
Matrix metering is good if you need to get the shot - ie. little preparation time. But you can't beat spot metering for perfect exposures. The shots I've posted are the ones that worked (by pure luck because I thought I was matrix metering) - the one's that didn't were horribly bad.
I would have though the IXUS would already have spot metering - my A40 does. You have to be careful with spot metering though because you need to have a good understanding of light and what neutral grey is - or have a grey card with you.
Greg, What about white balance, what setting did u use? I used cloudy on my Coolpix 5700 and it gave a little bit warmer tone, instead of that bluish/grey tint you had in your pics... (or did you do some colour correction?)
Nice photos Greg, the only thing i don't like is none of them were of my car!!! :goddam: Was a good turnout, hope to see more skylines next cruise :( And a HAPPY NEW YEAR TO SAU :Party: :boobies2: :rave: :alcoholic :spew:
It's a film camera - there are no white balance / colour settings as such. The particular "look" of the pictures are due to film I was using me trying to bring up the bad exposures to something more useable.
Nice photos Greg, the only thing i don't like is none of them were of my car!!! :goddam: Was a good turnout, hope to see more skylines next cruise :P And a HAPPY NEW YEAR TO SAU :Party:  :boobies2:  :rave:  :alcoholic  :spew:
I took photos of every car, but due to circumstances noted not all of them worked - I'd love to get out there and do a few more shots next cruise.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
