Well just had my motor taken outa my car and the news is not goog....
F%*@ked crank, broken conrod,Shattered pistone, bent valves..
Need a new replacement "Good" motor guys. any takers or should I say givers?
If you guys know of or heard of any late model R33 RB25det (preferably SII) motors going please send a pm or reply back to this as I am in a bad state (slightly pissed) trying to numb the pain a bit.
But not giving up as the rest of the car is very clean so want it going again. beens weeks now and really getting annoyed with driving the Hyundai Lantra S-Box around all the time..
Depressed Dazza..
https://www.sau.com.au/forums/topic/303616-motor-bit-the-dirt-kaput/
Depressed Dazza..
Er... may i ask WTF did u do to cause all that damage?
also
Good luck getting her running again.
also
Would you believe taking off from the lights & getting to 2nd gear changing before turbo spools up at about 2500rpm and about to get to 3rd and rattle rattle ,loss of oil pressure ,switch off and pull over. I was driving like a granny trying to save some fuel. Now if i was hammering it i could wear it butttt..
Dazza
Broken timing belt ???
inspected the engine today and what a mess. piston shatered and conrod twisted and snapped in several places . bent valves and head damages under number 1 Cylinder. block damaged around bore etc.....
pic of piston & rod listed as well
Dazza
Oh and the cam belt is ok less than a month old...
Were the Tensioner and Idler pulleys changed along with the timing belt?
Sounds like this has not occured as part of a 100k service or something (and needs to happen to avoid this exact issue)
R31Nismoid,
yeah ,
when I had the timing belt done , all pulleys & water pump were replaced...
as regards to rebuild time , boy would i love too but cash is short so i have 2 choices of either getter a 2nd hand long motor and then (replace belt,pulleys,water pump)
or getting a 2nd hand long motor which have been honed & re-ringed and then (replace belt,pulleys,water pump)
The 2nd optioned has been proposed/advised by my mechanic who said its a better start again knowing the state of the motor over just replacing a motor....(makes sense I guess)
I am not after a huge power build..was actually wanting to get to 253-250 rwkws originally
Dazza
I have 2 motors here, one has a rattle in the bottom end but good head (has had the head removed) and the other was just a good bottom end, was going to bolt the 2 together and make one good one for now and build a big banger later, have since pulled the car off the road and going straight to an rb26/30, they are S1 no idea what the internal differences are, as far as i know its only coils and afm that are different, if you interested send me a pm.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
