  • Replies 846
Posted Images
cheers for uploading that, good to see some video of my r34 hard to gauge how you compare to the rest when your in the car!!! I still think I gave andz in the evo a run for his money haha
ehh wilkor32gtr? i dont remember driving with a GTR
were u in the white R34 GTT?
was good fun following you around the track though ;)
hehe my first day @ the track
and I was too scared to do anything silly, took deposit that night, car is going on friday
not sure which R to get...34 is getting old, 35 is too dear just to drive 60k/h in adl
it's gotta be the 35!! That's what the track days are for to open it up!!!
you'r 32 looks good out on the track
Cheers :D
Looks like I may have done some real damage to the rear calipers from overheating them, one of them is leaking brake fluid now :D The rear calipers were red at the start of the day.
Looking at my front rotors it looks like the front pads have melted onto the rotors :O
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
