Auto Skyline with 10-11psi, 3' cat back and pod = 136 rwkw. Just got it dyno recently and haven't had any problem boosting to 10 psi.
I don't think it is the auto box you have to worry about just yet, but more you turbo because of the ceramic thingy. I think it depends on the condition of your turbo, not long ago I read another thread that some guy blow up his turbo and he was running the same boost as everyone else here.
If you search this forum (or SDU's for that matter) you'll find quite a few threads on how much boost to run on an R33 turbo, about 12psi seems to be as high as you wanna go is the general concensious (sp?) I think. Some turbos simply last thou even at 18psi plus, where as I've seen some fail at 12psi... back pressure, heat, clogged oil or water lines, theres a few factors involved.
As for setting the timing, on an R32 and possibly the (series one) R33 theres a little loop of black wire which goes into the ignition amp, this is for coil/cyl 1 and some timing lights will work off that, but its not very accurate. Removing your centre cover to get access to the coils, and then lifting coil 1 is the better way. You just put a short HT lead between the coil and spark plug and use a timing light off that. Much more accurate. Factory timing should be about 15 degrees BTDC.
My first (R32) Skyline wouldn't go past this without detonating, my second R32 Skyline would run 20 degrees even at 1.1 bar without issue. What my R33 is running I have no idea as my timing light packed a sad I just turned the CAS slightly counter clockwise and listened carefully for any pinging... I'll check it properly later but the quick and nasty way is advance till you hear it ping then back it off slightly.
Btw, remember to keep the coil grounded when checking the timing when using the HT lead. You will also need to unplug the TPS definately in an auto, unsure with a manual, but I think thats still the case.
My auto runs well at 180rwkw (a bit of a disapointing fugure)
I run 13 PSI, a PFC, FMIC, 3" exhaust and rising rate reg. My injectors are now at 70% (so i have plenty of room to increase power)
I am hoping a HKS2530 turbo will get me a lot closer to 250rwkw. I will also include a trans cooler and an electronic line pressure switch to make for crisp shifts and a cooler trans.
such low numbers for those mods ... 136rwkw ... i've seen manuals get 180rwkw ...
think you got something mixed up, dont think ne r33gtst with cat back and pod filter at 10psi has 180 kw at the wheels
more like 150-160 max
dont forget that you will always have less power through stall converters compared to clutchs for manuals.
eg your average 160rwKW should be 175 through a manual trans.
i am running 9 PSI on mine with 170rwKW. running rich as well as i have stock ECU.
auto, but mind you. SHE is a bullet
Well to give you an idea hippy, the dyno I went on my car made 136 rwkw, but I saw an R34 GTT (manual) stock on the same dyno and made 115 rwkw.
Then another R34 GTT went on with exhaust only I think and made 125 rwkw.
So I can't be too disappointed with my figure.
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
