My circumstances are a little different because I'm running a lowly CA S13 with no power but my water temps don't break 90 and my oil temps have only seen over 100 on a handful of occassions.
I'm running the stock clutch fan and shroud, alloy radiator, Greddy relocater, BTR oil cooler thermostat, Just Jap 13row oil cooler (mounted in driver side air damn under the headlight and my front bar is vented to feed it).
I'm just using standard coolant and Shell Helix blah blah 10w40 oil so nothing special.
I expect I'd be running higher temps if the car made more power but I watch temps like a hawk and run a few cool down laps when necessary (I can run 8 or so laps at time without issue, my brakes then become the problem).
As was said above, 130 is in my opinion the upper limit of safe, for me 120 is as high as I'd personally want to go. That does depend on your oil though, different quality oils will handle higher temps without breaking down. I use cheap oil so I play it safe with my temps.
Sustained water temps over 100 is a "no no" in my opinion.
Edited by ActionDan
i think this is great pin point answers that others getting to the track will need to consider on top of all the tire and susp settings as well top stuff! Cheers steve
Sustained waver temps over 100 is a "no no" in my opinion.
I woudn't dismiss the need for "servicing" your intercooler as well. Bent fins and track gunge over a period of time will effectively block any air flow to the radiator and reduce the intercooler's effectiveness as well.
Hi there,
i am very interested in the servicing aspect? can your repair bent fins? there is definately a whole heap of bugs and track gunge over the cooler!
anyway just a quick update - time got the better of my plans to go back to the standard intercooler and i convinced myself that surely the greddy unit would do a heaps better job then the standard unit.
i then got some tips off a drifter, where he suggested some polystyrene to help guide the air through from the FMIC through the A/C and hopefuly through the radiator. This wasnt very sucessful as it was to fidley for my impatient hands. Does anyone have any ideas of helping air flow in this area - im thinking sheet meatal?
looking then at bonnets with vents was the next thing - before i invested in this, i was looking at a HPI mag and noticed a jap 34 had its bonnet lifted with some washers. :down:
only mod i did was lifted up the bonnet slightly and realised that the max track temps got to was 100 degrees and oil 115, and this was after 5-6 laps. Cooling was great as after 1-2 laps it went back down to 90/105
i believe there is definately some air flow issues as Beer Baron stated and i am seriously contemplating removing the A/C and fitting a vented bonnet of some sort.
thanks for the tips guys keep them coming!
Cheers
Steve
I used waterproof foam rubber for cooling guides. Its available from clark rubber in sheets - its black and at a guess about 2cm thick. Becuase its waterproof it doesn't hold water/moisture.
I used an electric carving knife to cut/shape. The beauty of this stuff is that it retains its shape because of the thickness but will give enough to almost create a firm sealed fit between the panels and fit around wiring looms and other imperfections.
It also doesn't rattle/vibrate and as it is black.....has a stealth look about it. Because I oversized it, it wedges in between the relevant panels/cooler/etc so it doesn't require any dedicated fixing....however, this would depend on the span as the larger the span the more likely the need to specific fixing. Which I would imagine could be achieved with aluminium strap.
This sounds like an awesome idea! any chance you could take a couple of snaps and upload - what i imagine things to be are never what they are!
Cheers
Steve
Hi there,
Cheers
Steve
It's a matter of straightening the majority of the bent fins manually as it is usually only the front of them that is bent. Track gunge is a bastard of a job as it gets baked on with heat etc. I'll be asking the guys that work on the car to have a look at it as I have no idea how to take my front bumper off. I still run the factory grill in front of the intercooler so that saves it from most big stones/bugs etc.
Regards
Andrew
I actually have problems with not getting enough heat into the engine and around town would only see max of 70deg on the engine oil during the summer months with the sensor measuring in the sump. On the track it doesn't get above 90deg and i am doing some pretty quick times.
Do get higher intake temps which i want to fix by some ducting around the intercooler to front bar and radiator as well as a cold air intake of some kind becasue this would be having a fair bit of an affect on power levels.
I have had to make up a panel to block off the airflow to the oil cooler when driving around the street (until i tookit off at the track and lost it) to try and get heat into it, the thermostat seems to be working corectly and even replaced the spring just to be sure.
The oil cooler is an Earls type and sits on the passenger side utilisling some of the old std intercooler brackets and mounting points which is right in unobstructed air flow. I think this is the main reason it works so well and perhaps something for other people experiencing issues with oil temps on the track.
Matt
Matt,
I used to have my temp sensor in the sump too (greddy pan on SR) and found the temps weren't representative.
For instance it would drop back to 30 degrees when cruising on the highway and saw about 60 degrees max. I then shifted the sensor to the grex relo block and instantly I get oil temps at or slightly more than water temps which seems more legit.
my water temps only hit 90deg as well, might be worth logging it to show the differences between the two (in sump vs exit from block). The majority of people tend to say the differences are only minor between measuring in the sump to the block but would be good to see the two compared on a hot track day.
Here are some pics of my set up. The bleeds are tapped into the 3 bungs in between the exhaust ports. The water pump is a OEM housing with a John Bennett built impeller.
I really should have washed my car before posting those pics. :)
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
