hi all it seems like i've snapped the connection to the plate on the firewall on the clutch assembly on my 32 gtst so the clutch pedal is over the shop so it wont engage. apprently is a common fault. had alook and cant work out how to take the whole plate and clutch assembly out. any instruction/advice or experience would be greatly appreciated. is it normal to just weld it back on?
hey mate, had this happen to me just recently as well tho i was lucky the whole thing didnt come off completely and hold the assembly on with a coat hanger while getting it fixed (dont do this, not recommended but had no choice since its my daily driver). what the problem was, one of your spotwelds on the bracket might have snapped, a common problem if you have a heavy duty clutch or any clutch that has higher clamping force than standard. cheapest solution is to get it rewelded around the spotwelds and add a bit more weld to reinforce it on the way which is what i did. becareful where you weld or the material will get in the way when reinstalling back to the firewall. but if your willing to spend a bit more, the nismo solution as Elite racing mentioned is the best way to go as it doesnt cost much more than da factory one ($110 quoted for standard Nissan).
The assembly is held in by the same 3 bolts that hold the clutch master cylinder in place, and a bolt up behind the instrument panel (I found it easiest to remove the instrument panel to get at that one).
You shouldn't need to remove the instrument panel. A 9-12 inch 3/8 drive extension and 12mm socket should get it quite easily from underneath. You just have to worm it past a couple of wires.
But as said above. That one and the two that hold the clutch master cylinder on and it's away. Leave the pedal in place as it's gonna come out with the rest of it.
I recommend getting the Nismo one as it might save you a couple of dollars to get it welded but I have found that in around 50% of the time the metal will crack again within 12 months right next to where it was welded. It's much better to replace it with the already reinforced one and then forget about it.
Contact Link International on 07 3382 5000.
They are in Brisbane. Or I think Unique Auto Sports is the Nismo dealer down south.
Part number for R32 is - N-46550-RS580 Retail price is $148 but depending on who you buy it from, you can get them cheaper. They keep them on the shelf usually.
Hey guys,
Think this is whats happened to me... Except i am leaking transmission fluid from under the car... Car starts and i can put it in gear when the car is off but cant when it is turned on.... Its parked under my workplace and i need to get it out! any temp fix to get it moving back home?
I have turned the car off put it in gear then tried to turn it back on but it wouldnt turn on
Any help is appreciated
Cheers!
Hey guys,
Cheers!
Yes, you need to replace the clutch slave cylinder and/or the master cylinder. Considering there is fluid under the car, I would start with the slave cylinder.
Ring Nissan and buy it genuine. They cost around $100 for the R33 one. Dunno what the 32 one costs.
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
