Ask them to check the timing again, (belt missed a tooth)
If it has adjustable cam gear make sure the bolts holding it in place are tight.
Might be an idea to swap the stock intake pipe out for a stronger silicone one.
probably standard size. why do you ask?
purely because you often find with a thicker than stock head gasket you loose some low/mid range. only because of the drop in static C/R.
but if it's standard forget that then. look to the tune, and as others suggested make sure the cams are set and timed properly.
could also just be the dyno... does it actually 'feel' lacking in midrange? maybe run it down the drag strip and see what kind of time and mph it runs, or even just run it up for a power run on someone else's dyno and see what you get.
yes it feels lacking in mid range. big time!
i found the problem, the vct electrical clip was broken and disconnected. i replaced that and hello midrange powah!
trouble is, they tuned it like that. so i expect they wont mind re-tuning it properly now.
thanks everyone for your help and advice!
the people who mentioned vct were right on the ball. the electrical clip for the vct solenoid was broken!
its runs much better now, but will obviously have to be re-tuned. i dont know how they didnt notice this on the dyno though...
Ive seen every stage of your build so that would be a yes :P
HAHA
it lived there for about 3 months! it started as a motor in and out...
and then i bit off more than i could chew and added a turbo, clutch, split dump, $200 cat (which i then gutted in a fit of rage), ecu and bov.
the motor came minus camshafts. but my cams from the blown motor didnt turn in that head. so then i had to find a replacement head, have it machined, new gasket etc.
then we had to get all the water and oil lines for the turbo! the old turbo was oil cooled only, so whoever installed it just hacked off all the water feeds. needless to say, genuine nissan cost a mint.
and after all that, when the car rolled off the dyno at long last... the wastegate actuator fell off on the way home!
and now this vct problem! its been 5 months since my poor baby has been running at 100%.
cant wait until i get a gtr and do it right the first time.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
