Hi,
I thought there was a sticky on spark plugs but I can't find it, I've searched and found a few threads.
Its also an interesting debate in regard to going Copper and replacing every 10K or going Platinum/Iridium.
Any advice?
Finally, which one should I be using?
A BCPR7s/BKR7s ?
R33 GTR, standard tubo's, 1 bar boost, not driven too often if that makes a difference :D
Thanks,
Gareth
EDIT: Also is Repco a good place to buy spark plugs?
I noticed that performancelub has fairly cheap Iridium/Platinum plugs
300rwkw daily driven
i use bcpr7es @ 0.8
I'm only 250rwkw so I assume the bcpr6 might be a better choice. I'm unsure how to re-gap spark plugs so would prefer to buy the right size if possible :)
Ah bullshit you searched, i know you be telling furphies ;)
Just have a read of the Forced Induction Guide Gareth, its a sticky in Forced Induction.
It has a link to "what spark plug" or something similar, plenty of info for ya there :)
You wont need to gap the plugs. 1.0 - 1.1 willl be fine
i have been using 7's in my car all the way through, 150rwkw 185rwkw, 269rwkw, 285rwkw, 311rwkw and now 323rwkw
if you buy BCPR7ES or BCPR6ES they will both be fine..... and are already gapped @ 0,8
the BCPR7ES11 are gapped to 1.1
I would use 1 heat ranger cooler ie 7's on a stock engine with no mods and look at running 2 heat ranges cooler "8's" and smaller gap if you at pushing more boost ie about 1 bar.
Pending on condition of coils the larger gap may still work fine but due to age and condition every car is different.
http://www.skylinesaustralia.com/forums/Ng...eri-t68157.html
Ah bullshit you searched, i know you be telling furphies :)
It has a link to "what spark plug" or something similar, plenty of info for ya there :blush:
I read the general maintenance section, a quick check of the tutorials, and a search which brought up lots of debates about copper vs iridium.
Didn't think of the forced induction sticky :P
Besides you overrate search, I was searching for "spark plug" or similar, I didn't know what terms would bring back something useful :P
I'll just use BCPR7ES (-8 gap) then...thanks for the help (or 6ES if I can't get them).
Thanks everyone!
I think if there is no trailing dash and number (-8) then the sparkplugs are 1.1
ie. BCPR6E are 1.1 whereas BCPR6E-08 are 0.8
Ive been using BCPR6E's on my car, but ill be trying out 7's because ive noticed speckles on my sparkplugs which indicate that they are too hot.
BCPR6E are better than BCPR6ES. The 's' stands for standard tip whereas the other has a v-groove tip which they say is better.
Also, stick with coppers and change them every 10,000km.
im with hamish, ive got some BCPR7ES-11 rolling around the glove box of the daily. where as the BCPR7ES with nothing noted on the end are 0.8's.
by the by i run BCPR7ES and well under 250rwkw
my mistake, no dash number means default 0.8
Although according to their site they say 0.9
http://www.ngk.com/results_cross.asp?pid=BCPR6E
Projected Tip, JIS Height, .035" (0.9mm) Gap
More information on V-groove sparkplugs (BCPR6E no 's' at the end)
V-Power spark plugs are a patented design by NGK to improve ignitability and reduce quenching. Ignitability is improved by the V-groove cut in the center electrode parallel to the ground electrode, this directs the spark to to the edge of the center electrode thus exposing it to more of the air/fuel mixture. Quenching is reduced in much the same manner, drawing the spark to the edge of the center and ground electrodes reduces the surface area available to quench the spark. See quenching for more info.
i use NGK BKR7E in an RB26
does anyone else use these plugs
Looking on the website i posted above, the BKR7E feature the v-groove whereas the BCPR7ES does not. There doesnt seem to be a BCPR7E on their website so it looks like if you want the v-groove you need to get the BKR7E.
This assumption is all based off the ngk.com website though.
He had some kind of racing plug in there:
http://www.ninjapower.co.uk/product_info.p...-ngk-r67018-x-1 an NGK: R6701-8
Anyway, I've put the BCPR7ES in now, it was a little challenging but its done now, thanks for the advice everyone.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
