Hi Guys,
Just thought I would link you to my car on the dyno at Hyperdrive.
Just wanted to say thanks to Oz and Cem for all the hard work they have put into my car.
Also thanks to Andrew at Hyperdrive for doing such a great job on the tune and looking after me.
Also what oil cooler kit would you recommend me buying and from where?
I would like one before I do a track day.....! :D
Cheers,
Ken
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/
Well done man, that thing is beasty!
What plans have you got for it in the future?
Thanks Martin!
Not sure but I only wanted 350 out if it at the start but I got 400 so im happy (at the moment) haha....
I will take it to the drags soon and im thinking of joining SAUWA but I don't seem to find the time to even hit the drags :D
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5046961
Nice one mate :) Love that thing, really do, you've put so much work into it, has to be the cleanest R34 I have seen in a LONG time.
Now get your mate to buy my GTR.......... ;)
Thanks Chris :D
No your keeping the gtr, its mint!
How dare you try to sell it haha :)
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5047241
Nice. Hyperdrive do great work and Andy is a champ.
Is yours external or internal and is it 0.82?
You got to love the gt3076r i couldnt be happpiers with mine. I just wish i had a 3litre
Edited by Pattygtst
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5047433
That's a sweet achievement mate, especially on Hyperdrives roller.
Thanks Clint, yeah hyperdrives dyno is harsh...
I was thinking of going All Star for a power run on the Hubs and getting a better looking dyno graph...
But thats being a hp fan boy haha ;)
Mine is internal but im using cams with 17psi from a GT3076 so it works well.
I went for internal to keep it street friendly :)
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5047461
I went for internal to keep it street friendly :rofl2:
I have same turbo but external gate for my 34 sedan, also have tomei cams , greddy plenum , 6 boost with 50mm trust gate .. Andy will tune it once i done all the fab work
Hey just as a matter of interest, whats this thing like on petrol?
LOL choose 1 .. power or fuel economy :domokun:
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5049033
Its actually not to bad.. but it really depends how you drive.
When I just had the basic bolt on mods with a tune I was pulling 400-410 on full tank (BP Ultimate 98).
Right now I average about 370-380 on a full tank but like I said really depends how you drive the car :domokun:
Nice, with the external gate you will be able to boost it much harder.. Engine Stock internals? Just the cams done?
Also I would like a greddy plenum, that is my next engine mod... Makes the engine bay look like SEX :rofl2:
Edited by KEN-R34
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5049065
Lol yeh i know its not going to be efficient, i just wanted to know how much he gets to a tank driving like he usually does.
Just to be the devils advocate, i know of a certain eco car that does 0-60 in 2.5 seconds. The Shelby Ultimate Aero EV has 1000hp, 800lb-ft of torque, and gets 400-500kms out of a charge. Absolutely no petrol involved :rofl2:
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5049074
Also I would like a greddy plenum, that is my next engine mod... Makes the engine bay look like SEX :domokun:
Im only after 400 . Neo in my 31 has greddy plenum on it , from throttle body to cooler the pipe is 300ish long :rofl2:
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5049168
The 'Fuel Economy & Hippies' forum is that way..
lol...
Im only after 400 . Neo in my 31 has greddy plenum on it , from throttle body to cooler the pipe is 300ish long :P
You will make 400 easy on your 34.
Going for 400+ RB25 with stock internals is a bit risky but then again depends how you drive it.
Your 34 is a track car right? Your going to give it a good thrash most of the time :(
How man ks has your neo done?
I would like to know how long your engine lasts with 400 usage on the track.
Don't mean that in a bad way at all.... could last a very long time who knows.
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5049293
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
