well got myself a 1989 r32 shell back in october 09. has basically everything minus engine and diff. in a few months i will be hopefully be getting a 1jz-gte installed by nizzpro performance.
http://www.nizzproperformance.com.au/conversions.html (top right)
after a little bit of research, i decided this was the route i wanted to take, and found a shell that had basically everything minus what is included in this package.
***pics soon***
mods that i am planning to install to get the car running:
HSD - HR Type Coilovers http://www.otomoto.com.au/HDSystems/hrseries.htm
KAAZ L.S.D - Basic - 1.5 Way http://www.slidingperformance.com/store/in...mp;productid=74
future mods that aren't so important:
- haven't decided yet, but either 17" or 18" wheels with a decent offset
- comfy bucket seats for driver and passenger
- gauges, boost controller etc.
- upgraded brakes (rotors, pads and brake lines)
https://www.sau.com.au/forums/topic/304937-soon-to-be-1jz-gte-r32/
iv been looking around at different brakes, ecu's, coilovers and gauges and decided on the following:
dba slotted rotors, hawk hps performance pads, goodridge braided brake lines, tien super street coilovers, defi gauges and a kaaz lsd (probably a 2way).
after i while of getting used to the car il be upgrading to a microtech ecu with hand controller, aluminium radiator and some 17" rims.
God damn a 1J in there will be pretty crazy to drive I reckon. They go good in a fat arse soarer imagine it with only 1250 kgs to push!
Just out of intrest sake do you know what your 1J weighs?? and is it VVTI?
Cheers.
  • 1 month later...
  • 4 weeks later...
  • 2 months later...
skylines still in the shop. apparently they been a bit busy, dont really care so not rushing them. crossmember and custom engine mounts are done. engine will be in and mostly wired by end of week. Organised with nizzpro to get a rwc done there, so i can drive it home wootwoo!!
went down to see the progress today. just waiting on my mate to email me the pics.
during this week:
-custom crossmember and custom engine mounts were made
-engine was prepped and dropped in place
-the coilovers and slotted rotors that i supplied are installed
-put on a T70 turbo
-hicas lock bar installed
by next weekend when i go down next, most of the wiring will be done, fmic will be installed, and exhaust will probably be done.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
