well got myself a 1989 r32 shell back in october 09. has basically everything minus engine and diff. in a few months i will be hopefully be getting a 1jz-gte installed by nizzpro performance.
http://www.nizzproperformance.com.au/conversions.html (top right)
after a little bit of research, i decided this was the route i wanted to take, and found a shell that had basically everything minus what is included in this package.
***pics soon***
mods that i am planning to install to get the car running:
HSD - HR Type Coilovers http://www.otomoto.com.au/HDSystems/hrseries.htm
KAAZ L.S.D - Basic - 1.5 Way http://www.slidingperformance.com/store/in...mp;productid=74
future mods that aren't so important:
- haven't decided yet, but either 17" or 18" wheels with a decent offset
- comfy bucket seats for driver and passenger
- gauges, boost controller etc.
- upgraded brakes (rotors, pads and brake lines)
https://www.sau.com.au/forums/topic/304937-soon-to-be-1jz-gte-r32/
iv been looking around at different brakes, ecu's, coilovers and gauges and decided on the following:
dba slotted rotors, hawk hps performance pads, goodridge braided brake lines, tien super street coilovers, defi gauges and a kaaz lsd (probably a 2way).
after i while of getting used to the car il be upgrading to a microtech ecu with hand controller, aluminium radiator and some 17" rims.
God damn a 1J in there will be pretty crazy to drive I reckon. They go good in a fat arse soarer imagine it with only 1250 kgs to push!
Just out of intrest sake do you know what your 1J weighs?? and is it VVTI?
Cheers.
  • 1 month later...
  • 4 weeks later...
  • 2 months later...
skylines still in the shop. apparently they been a bit busy, dont really care so not rushing them. crossmember and custom engine mounts are done. engine will be in and mostly wired by end of week. Organised with nizzpro to get a rwc done there, so i can drive it home wootwoo!!
went down to see the progress today. just waiting on my mate to email me the pics.
during this week:
-custom crossmember and custom engine mounts were made
-engine was prepped and dropped in place
-the coilovers and slotted rotors that i supplied are installed
-put on a T70 turbo
-hicas lock bar installed
by next weekend when i go down next, most of the wiring will be done, fmic will be installed, and exhaust will probably be done.
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
