Hey again everyone, I was hoping somebody might be able to help me sort out an issue that I'm experiencing after fitting a new HKS EVC-S boost controller on my S2 Stagea RS4S.
When the controller is off the boost comes on at wastegate spring pressure (which on my Stagea is around 5-6PSI) so without the dual-stage in place it sits on the lowest possible pressure, thats not the issue however when I turn the boost controller unit on and dial in enough boost pressure for around 9PSI I can hear something (which I presume) like the HKS solenoid clicking quite a fair bit. There is no clicking when the unit is off however.
The boost is stable all the way to 9PSI with no overshooting or surging and no hesitation from the engine. So its defiantly something along the lines of the boost controller unit when its on.
Could anybody throw some suggestions at why this might be the case? Have I got the unit set up incorrectly in someway? After searching google a bit I've found theres plenty of info on clicking solenoids but they seem isolated to Greddy and Blitz units, and even then its not conclusive.
I was maybe thinking the boost setting I've got may be asking to much from the solenoid too early? Full boost at 9PSI comes on around 3500RPM.
Hi I had the same problem with my greddy unit. The solution is very simple and i presume it will be the same for yours. You need to put a rubber grommet between the solenoid and the car. The solenoid will still click the rubber just stops the noise traveling through the car. I hope this helps.
Thanks for the suggestion never thought it might be something as simple as dampening the vibration of the unit itself so fingers crossed that might be the cause. I'll hunt down a rubber washer today and report back if the clicking gets softer.
  • 3 weeks later...
i just installed my hks evc-s got the same issue with clicking... at first it wouldn't do it but eventually i heard it like 2 days later... very very odd...
i also have a rubber washer between the unit and my chassis, but clicking is still loud as fk lol
so i think if the problem lies within the over boost function i may just tune it using the over boost a bit more (currently its set to 0 whilst using the offset to control the psi)
its not a problem, the solenoid will click when its 'adjusting' the amount of air passing. your factory ones do the same thing, they are just quieter, and probably slower (i cant remember the frequency, 10Hz?) but aftermarket ones are generally faster and make more noise, but they do a better job. like a bigger exhaust, noisy, but more power :P
isn't it open until 4500 then it starts pulsing?
open = wastegate spring pressure
pulsing = higher boost levels
my rs4s runs 7 psi with the solenoid off and 10 with it permanently grounded
if it was closed below 4500, it'd be freeboosting. it just pulses at different rate after 4500.
WRONG . the line to the solenoid is teed into the reference line to the waste gate . closed = waste gate pressure. open it bleeds off as much air as the factory restrictor will allow.
why do you think bypassing the solenoid is the same as having it permenantly earthed
thats right, factory solenoids work in parallel to the turbo, aftermarket ones generally are in series with the wastegate actuator line.
why? because if it fails, it will most likely lock in a closed position and the car wont overboost and die
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
