what happened?
Have you got the car finally running?
nothing happened, just not really confident with the one in it
and yep, its at ESP at the moment. heard it start for the first time yesterday, it sounds angry and loud. i'll probably need to muffle it.
I have a auto rb25 box for sale
no thanks, need a manual for skids. :D
https://www.sau.com.au/forums/topic/305010-wtb-gearbox/#findComment-5049749
Sam busted his at OP last year and is probably going to rebuild his one soon. I've got a whole pile of broken boxes now so I think I'm going to have to as well.
I'm also thinking about rebuilding the Silo or maybe even another one that is straight. I need to make it more quiet but have more power due to all the places complaining about noise! Pretty lame!!!
Edited by StinkyPoo
https://www.sau.com.au/forums/topic/305010-wtb-gearbox/#findComment-5049834
  • 9 months later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
