Yep Merli, I learnt the hard way with a fuel pump upgrade and stock ecu.
No point wasting money on tuning the ecu to suit the RB20 when the RB30 will be in there soon.
Short motor should be ready 3rd maybe 4th week of Jan (waiting on forged pistons). Head etc.. is already done.
Its going to be run in with low boost and stock ecu with the rings bedded in on the dyno and a few checks to make sure the stock ecu will not run to rich/lean etc.
I've been told to run it in with the stock ecu then slap in the new ecu with injectors turbo and let it rip.
terry.m, good idea getting a decent Jap exhaust.
You can pick them (cat back) up in stainless for $700 in excellent condition second hand. They do bolt on exactly. From there look at a front pipe and highflow cat (or decat pipe - for racing use only of course:))
I noticed you have a '95 skyline - seems several people here have had some good results with the 95 ecu, in some cases it seems to produce alot closer to 'good' air fuel ratios than some of the other years.
Getting a bleed valve and putting the car on a dyno will tell you alot more about where your AFRs are. From here I would recommend a cooler - as colder charge air will deliver alot more power, I fried my clutch as soon as my cooler was fitted (but I already had a power fc).
From here, if needed, engine management of some type. There are heaps of different options around, and as merli posted earlier, get it right the first time and save a fortune ( I have got it wrong a couple of times, and both times it ended up costing me over $1000+ to learn the hard way:))
Also, dont forget suspension and brakes. By setting up your suspension correctly, you will be able to get the power down alot easier. Simple and relatively cheap options like cradle bushes help, also, not a cheap one, but decent coilover suspension or coils and shocks will make a huge difference to how the car drives - and driving pleasure is what it is all about.
You will probably realise that you can spend as much money as you want, but do it smart and you wont regret it.
Lastly (but not least), welcome to SAU.
Steve
Thanx Steve,
It looks like I may have to hold the mods off for a while...I am suspecting a new clutch is needed. On 2 occasions now, I've reved to around 3000 - 4000 rpm, let the clutch out and...nothing! The revs go up to 6000rpm but I'm not going anywhere. The stupid thing is that it doesnt happen all the time. I tried taking off in 5th at 1500rpm and the engine stalled, this tells me that there is nothing wrong with it. There is no crunching in any gears except for the infamous 1st to second cold change.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
