  • 4 weeks later...
You guys harping on about how awesome the originals are... the anti-progress committee called, they want their incandescent bulbs back.
I for one would love to see someone adapt LED/refraction tech into modernising the signature skyline lights. Not that rubbish shit that gets peddled out of $2 china parts stores. Like what HSV's done...
sayin I like the insides of em, someone should modernise skyline lights with them... not just one circle but about 4 concentric circles. would look epic.
