Hi All
Trying to get rid of the wreck taking up my garage. message me for what you want and ill help you if i can. Some things still available listed below.
Make offers on what you want.
Front bilstein shocks (hard, near new)
Lowered king springs
Removable steering wheel with boss kit.
RB20DET 5 speed with noisy input bearing (has been for 13,000 kms and not getting worse)
R32 Sedan RB25 auto diff head, tall ratio, good for that torquey 3ltr, non LSD
Rear lights, bumper, boot lid, spoiler, front guards, bonnet, both doors with windows. All factory metallic wine/red
Factory RB20 intercooler
front and rear windows
Various interior parts (ask)
Std rear shocks
R32 RB25 motor with flywheel and good clutch, clean runner but needs welsh plugs changed in block.
Car has L/H rear damage but is repairable for road or race, not written off, prepared to sell whole if anyone wants it. Has four stud hubs as I put the five stud GTST gear on my other car. Still rolling so can be put on a trailer no worries.
Also
R32 gtr cams and buckets (no shims)
R32 gtr std exhaust manifolds
Reasonable offers will be taken on everything
Prefer pickup or meet in Sydney campbelltown/bankstown areas
https://www.sau.com.au/forums/topic/305462-r32-gtst-wrecking-and-gtr-cams/
Mate,
How much for the tail lights? Also do you have a good condition Dash pad.
Regards
Will take 60 for the tailights. The dash is not bad but has a small buldge above the clove box in the normal spot also it is a bit heat shrunk and hard as well, edges raised around the vents etc, would be ok if yours is buggered.
I sent a PM but have got no reply so i guess ill post here
Im after the surround that goes around the Dash instrument cluster (speedo/tacho etc)...the one in the 32 which has the light switch/hazzards/radio/wipers control on it. Im after this with all switches. What is the condition of this part? Picture emailed to [email protected] or sms/call me on 0401 317 009
Cheers!
Cheers!
Hi,
Sorry for the delay. The switchs are not all good. I have used the light switch in my other car. if youe still interested i will post a pic of the surround for you.
How much to post/courier it to 0812 Leanyer, Northern Territory????
VERY INTERESTED!!
Not sure but could find out next week if you really want it. Probabaly going to cost more to post than to buy!!
I don't mind, but my brother lives in wollongong so I could probably arrange for him to pick it up from you for me and then he can send it later to save me some money. If thats easier for you let me know asap :worship:
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
