Hey guys
i recently went camping and my front bar had a bit kiss to a rock
I didn't see on the floor devo as ;)
but now i'm in the market for a new fron bar :)
I found this one on j tuned but don't no what it's called if anyone knows
can u please help me out
and if any can post up some clean front bar that would be helpfully
cheers everyone
I don't know what the frontbars called man when I find out i'll pm you maybe we can get it cheaper for two ;) I've baught stuff from psi parts there a good company
just wish I knew where to buy it from
Hey guys
I didn't see on the floor devo as :)
cheers everyone
In the 3rd post by Trent 26 that's the do luk front bar but instill don't know what the front bars called
in the pic I posted :)
The closes it looks to is the Do Luck Front Bar but for a R33 GTS-T, but the pic you posted it is on a GTR.
GTS-T front bar on a GTR.
Suck, I can't find the article on that R33 GTR on J-Tuned, cuz they updated the website and have all new cars no more archives.
same front bar as psi parts has on their demo car, and yep its do-luck... nice..
it isnt actually - looking at the bar there are a few differences in lines accross the bar
lower lip is smooth not ridged - angles on the side openings are different
wilyawns pic is the right bar
Their both Do-Luck ones, which one do you prefer?
GTS-T or GTR Do-Luck front bar, up to you.
IMO the GTS-T one looks better but without the line that goes across the intercooler. (Like the 1st pic you posted)
Yer I was swinging that way I've delt with fiberglass before so if I was getting
that's front bar I would cut that bit out and patch it up ;)
I can also get the gtr one but made for gtst
so options are still there
got to remember some molds come out different from different places, i've got a few mates with do-luck fronts and sides and they look slightly different, more curved etc on one of them.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
