mate you can have it for $200.
you won't be able to get it for 3 weeks as me & kate are in europe for a bit.
i'll pm you when you can come get it, any time after the 22nd novemeber should be alright.
Get off the interwebz and start enjoying Europe mang!!
  • Replies 1k
Posted Images
not for another week yet. where i am at the moment the interwebz is the only thing that keeps me sane.
Bugger i was gonna get it then i kept reading. Rob if you like i can give u a hand with your head. So what does everyone reckon for a cruise on sunday? Drive then lunch?
still got heaps of other things you may want. thanks,will let ya know when it happens next year.
i am keen as to go for a decent cruise now there are few more members getting around.
So here's a stupid Nissan engineering fault. When your brake light switch (off of the pedal) fails, it turns your damn brake lights on!
Nice suprise finishing work and having a completely flat battery down to 0.3A :rant:
haha yeah phil i had similar problem the set-up on the sil's have a rubber bung to hold the switch in the off position and being an old car it was f**ked n fell out :( put a nut n bolt in the hole all good :P
oh well dont i feel like such a dick today, when i left today i thought u had left ur tail lights on, so i checked if ur headlight/parkers were on and they werent so i thought i must have been mistaken.... my bad. unsure.gif
car looks good phil, shame your stripping it. wish i had the room for another car.
i like how the timing cover turned out :thumbsup: i might do the same my set.
so has anyone bought your rear brakes & handbrake cables???? if not i'll take the lot, let me know $$
Edited by robbo_rb180
Nice
This is why I like your car and dont want you to part it out. Photos of rear?
I know, but it needs to happen :(
Don't actually have a full rear shot. Will have to ask if he has one.
Hahaha. I checked my lights two times during the day thinking why the hell they looked like they were on. But there was no sign of any of the lights being on so I put it down to the sun being in a perfect spot to make them look lit up. Then at around 1pm they were off so I thought the sun wasn't in that perfect spot anymore - But it was because the battery was completely dead lol.
Yep will let you know, no one has called dibs yet.
Saw you working on your car around 6pm last night Phil, was gonna stop and say g'day but had an appointment with a real estate agent. At least if your car is gonna play up it did it in front of the right shop haha
hey guys if anyone in townsville is looking for spare 32 interior, front bar, rear bar, front quarters or GTR front quarters, let me know. im selling. i have to clear this stuff out before i move in mid december.
ps. All this stuff needs paint. interior parts are NOT in good condition, throw a offer at me, im not asking much
Edited by jamie curran
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
