Hi all, I wanna get HID lights in my R34 GTT, My friend pointed out to me that it came with zenons stock but for compliance regular bulbs had to be put in, so the car still has the zenon headlights just no bulbs. I've been looking around trying to work out what i need and im just hoping you guys could help me out. I'm after the white light with subtle blue tinge (not full on blue like euros and not yellow either) so what globes will i need (i know they had an `x'K name to them) and also what i need to buy to get the hid thing down. And where i can find cheapish (but good) things to do it with, ive seen a few sets around ebay but like i said, im not sure what i fully need.
Thanks.
https://www.sau.com.au/forums/topic/306056-hid-lights/
You need to check what bulbs are in it at the moment. It will be either H1 or D2R bulbs in there depending on what they changed them to at compliance.
Then depending on which bulb you have (D2R or H1) just buy a HID kit for that bulb. The kits usually comprise of a ballast and the actual HID bulb itself.
You can buy them off ebay, which are usually china knock offs, or through the vendors / group buys that are done on here and normal jap workshops.
Best if you just take your car to a workshop and see if they can get HID's for you and find out what bulb you have. You can't even put a proper paragraph together so I doubt you'd be able to wire up a HID kit.
P.S for the white light with blueish tint you'd want a 6000K hid. Or you can buy the original xenons for your car off someone on here if there's one for sale.
Edited by R34 GTTTTT
https://www.sau.com.au/forums/topic/306056-hid-lights/#findComment-5062626
Kk thanks for that info. Ill check the bulbs next chance i get and go from there. Oh btw, if not being able to put a paragraph together is good enough for a very high english mark in the hsc, i think its fine for sau. Especially since this is a car forum not an english lesson. :P
https://www.sau.com.au/forums/topic/306056-hid-lights/#findComment-5062736
+1 for NYTSKY HID kit..
your obviously a kid just outta school.. But writing on the forum in the correct manner helps everyone on here understand you which in turn will ensure they answer your question.. correctly.. if they get confused cause your lazy or illiterate then your not gonna receive help..
HSC won't help you here buddy
https://www.sau.com.au/forums/topic/306056-hid-lights/#findComment-5064133
