Hi
Just wondering if i need to add some more oil since im running a HKS R Type oil cooler. I know std rb25 is 5.5L with filter but i am now running a s15 filter (its smaller) and the extra lines for the cooler
thanks
5.5L :P Pretty sure it is like 4.5L - 5.0L depending how you drain it (warm, cold, vacuum drain, gravity drain etc).
I just fill my cooler up seperately, since I take it off to drain it for an oil change (highly suggest this too, it's really not that hard if it's in an easy to get to place). Then put the usual 4.5 litres or so then run the car, let it cool down and then check the dipstick.
  • 1 year later...
sorry to dig up a new thread, im flushing my engine oil. wondering how much to re-fill
the oil in there has only done 30 dyno runs as it was used to just flush and clean the engine.
i found the norm is 4.5l for the engine, say 500ml for cooler +some for lines.
now im taking it to the track monday. so i was told to overfill.
how much would i put in? 5.5L? 6L?
stock sump btw
my 25 with hks type s cooler takes 6L abouts, I know its more than a single 5L oil container
oh yeah thats mounted in passenger side as well...
Edited by 75coupe
fill it to the hump on the dipstick, start it and let it run for a bit, then check the level again
no one can give you an amount in litres as it varies, mostly on how much oil was drained, ie is the cooler completely empty?
  • 3 weeks later...
Hi guys,
everyone is saying to put in extra oil then start the car and let it run, do i assume let it run all the way to operating temp as the HKS oil cooler has a thermostat built in meaning it will not fill the cooler until the thermostat opens.... this would mean your overfull until this opens correct?
Also wondering how the oil would drain from the cooler knowing that it is lower than the lines running to the oil filter and by means of gravity the oil would remain in the cooler?
sorry if these are noob questions my logic could be way off, i am looking at putting a cooler on very soon and have never had one to know the answers.
It doesn't unless you remove the oil cooler and pour it out.
Also most oil thermostats don't completely block of The oil cooler so it should start to fill as soon as you crank the engine.
When fitting new oil cooler kits I always disconnect the ignitor and fuel pump fuse and crank the engine for a while to pre fill the lines and cooler so the engine sees oil sooner rather than later when u fire it up properly
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
