Hi
Just wondering if i need to add some more oil since im running a HKS R Type oil cooler. I know std rb25 is 5.5L with filter but i am now running a s15 filter (its smaller) and the extra lines for the cooler
thanks
5.5L :P Pretty sure it is like 4.5L - 5.0L depending how you drain it (warm, cold, vacuum drain, gravity drain etc).
I just fill my cooler up seperately, since I take it off to drain it for an oil change (highly suggest this too, it's really not that hard if it's in an easy to get to place). Then put the usual 4.5 litres or so then run the car, let it cool down and then check the dipstick.
  • 1 year later...
sorry to dig up a new thread, im flushing my engine oil. wondering how much to re-fill
the oil in there has only done 30 dyno runs as it was used to just flush and clean the engine.
i found the norm is 4.5l for the engine, say 500ml for cooler +some for lines.
now im taking it to the track monday. so i was told to overfill.
how much would i put in? 5.5L? 6L?
stock sump btw
my 25 with hks type s cooler takes 6L abouts, I know its more than a single 5L oil container
oh yeah thats mounted in passenger side as well...
Edited by 75coupe
fill it to the hump on the dipstick, start it and let it run for a bit, then check the level again
no one can give you an amount in litres as it varies, mostly on how much oil was drained, ie is the cooler completely empty?
  • 3 weeks later...
Hi guys,
everyone is saying to put in extra oil then start the car and let it run, do i assume let it run all the way to operating temp as the HKS oil cooler has a thermostat built in meaning it will not fill the cooler until the thermostat opens.... this would mean your overfull until this opens correct?
Also wondering how the oil would drain from the cooler knowing that it is lower than the lines running to the oil filter and by means of gravity the oil would remain in the cooler?
sorry if these are noob questions my logic could be way off, i am looking at putting a cooler on very soon and have never had one to know the answers.
It doesn't unless you remove the oil cooler and pour it out.
Also most oil thermostats don't completely block of The oil cooler so it should start to fill as soon as you crank the engine.
When fitting new oil cooler kits I always disconnect the ignitor and fuel pump fuse and crank the engine for a while to pre fill the lines and cooler so the engine sees oil sooner rather than later when u fire it up properly
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
