Catkicker. There is a textbook amount. On the ugly poo gtr/gtr33/gtst33 the amount is about 3.8L. But you can never get it all out.
I normally get in 3.5-3.6L. That's why you just fill it till it comes out when the car's level. If you tried to put in 3.8L, it would all just pour out the side filler hole.
On the r ugly poo gtst, i believe the amount is about 2ish litres. Just fill it till it comes out then bung it.
Yeah, 3.8L will be heaps for the r32. You should have a fair bit left over for top ups/doing a mini change later or something.
For the r33s, 3.8 is touch and go. I have used almost 4 L once, but that was a dry fill (box dissasembled).
PS: have you looked at the redline website - shockproof is not recommended for boxes with synchros. Just thought i'd tip ya on that
Edited by MANWHORE
Yeah I have heard that but a lot of people use it and rave about it. However then there are 2 sides to every story and others have used it and blown gearboxes.
From what I have read, it is excellent if your box is getting tired (ha ha) but I am not sure if there is something more suitable. I am starting to get occasional crunching in 1st and 2nd so figure there is no harm in trying it... Can anyone reccomend anything better?
You are spot on about two sides of the story.
Yes, it does give superb feel. Automatic transmission fluid also gives great feel too, but isn't good for your box either.
I personally haven't used shockproof in my car. One of my friends is using it, and it made a huge difference in feel (then again, even putting cooking oil would have because the oil had probably never been changed since factory. It was almost like mud).
I personally use and stand by motul gear 300. It's fully synthetic and it's about the same price as shockproof. About $30 a litre.
  • 2 years later...
  • 4 weeks later...
Just one thing i feel like adding to this, is if youre like me, and have had to work on an R32 that is (illegally) low, so low you cant even get your arm under it.... then there is another way to get the oil in, other than the filler bung.
We ended up jacking one side of the car up a little, so you could JUST get your fingers on the filler bung (to put it back in), and since the box had just been out, the shifter wasnt installed. We then proceeded to fill the box, using a funnel made of an old 2.25 sprite bottle, through the shifter hole, untill it started to dribble out of the filler hole. When that happened, we all poo'd our pants and my mate jammed his arm up under the car to put the bung back in place.
Of course, car was too low to tighten it up like that, so we had to jack the whole car up enough to get under and tighten bung back up. Put shifter back on, and tell kid to come pick his stupid car up and get it out of our sights.
That, is my life story.
  • 2 years later...
Did mine today. Wasn't as hard as I thought it would be. From my experience here are a few tips
If you are having issues with getting the drain plug undone, leverage is key.
If you have access to a hoist, run some flush through the box then drain that as it gets rid of excess oil to allow for your new clean oil
I used a pressure spray bottle 2L and it pretty much did all the pumping work itself, I took the one I brought from SCA back as it broke within 30seconds...
Also, if you for some reason cannot get your fill plug out, it may be easier to fill it through the reversing switch. I wouldn't recommend it but is a last resort kind of thing.
Now to go make a CAI and light up skyline sign :)
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
