Hi guys, looking at purchasing my Injectors soon. I'm going with Sard 650cc top feeds for my Neo, but I don't know what this whole impedance thing is about. I'm still learning while I'm building so any help would be greatly appreciated.
I understand that it has something to do with the type of ECU your using, and for me that will be ViPEC, so yeah if anyone can help that would be great.
Cheers
Daniel
https://www.sau.com.au/forums/topic/307130-injectors/
Stolen off injector.com
What is impedance?
Impedance is the electrical resistance of the electromagnetic coil inside the injector. This is measured in ohms and can be determined with an ohmmeter. Injectors are classified as either high-impedance (also known as “saturated”) or low-impedance (known as “peak and hold”). High-impedance injectors usually range from 11 to 16 ohms of impedance, while low-impedance injectors usually range from 0.7 to 5 ohms of impedance (these impedance numbers are based on what is currently available in the consumer market and are subject to change). Most OEM engine computers are designed to control high-impedance fuel injectors. Low-impedance injectors are generally preferred for racing or ultra-high performance use because they respond more quickly, but aftermarket engine controllers are usually required to control them.
https://www.sau.com.au/forums/topic/307130-injectors/#findComment-5074706
see what impedance the injectors your already running are
ie: GTR run low impedance from factory so the car has the resistor
If your car is already running low impedance new low impedance will plug straight in as you already have the resistor
Edited by gazza750
https://www.sau.com.au/forums/topic/307130-injectors/#findComment-5075454
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
