You will never get 400rwkws with a GT3582 on a stock Rb25det on 98 fuel. maybe E85 with 500Hp Shot Nos if engine doesn't fly in pieces.
Edit: Never mind. Its probably Nismoid's typo.
ye, was meant to be 300rwkw - totally missed it :banana:
i've altered it :D
  • Replies 93
change the cat, you wouldnt believe the shit ive seen mates go thru trying to tune well built cars with a cheap cat that had a 3mm smaller ID than the rest of the exhaust.... 2-400 bucks on a proper cat and birth to the monster within
the stock cat is 2.5".
and remember, the smallest point in the exhaust basically determines the size of the exhaust. Doesn't matter if you have a 4" dump and cat back, if you have a factory gutted 2.5" cat, that is the size of the exhaust.
You can un-bolt the cat and bore/grind the stock flanges out to 3" (there is enough meat there) and put a straight through 3" pipe in the stock flanges. Then weld the original cat body back on for a stock look (a good idea if transport/police are hard in your state).
the cat may be gutted but its still necked down = turbulance and poor flow.
Edited by Mr. Untouchable
hmm last i checked the stock cat flanges are 3" cause it bolts up to my 3" dump and cat back exhaust.. but it could be an option..
would running my external gate to atmosphere help at all?
i made a video going from 20-160 but my net is capped so i cant upload its way 2 slow :)
Edited by l0WRB
the flanges have the same shape size etc as aftermarket 3" gear but the actual inner diameter is like 63mm for memory which is basically 2.5" bore the suckers out to 3" and put a piece of 3" pipe in there or buy a pre-made decat.
and dumping the gate to atmo wouldn't hurt. less gasses trying to escape out the exhaust pipe.
mate id be trying the cat, maybe a exhaust cam gear.
after that, garrett .82 rear and a nice highmount manifold.
venting the gate to atmo wont help, but try unbolting from before the cat... it really could be the answer.
as stated they have a 2.5" internal diameter, the car i mentioned earlier was only out by a few mm not half an inch lol
depends where the gate is plumbed back in. If it plumbs back into the dump not far from the turbo I disagree.
if it plumbs back in further down the exhaust near the cat I cant see it being a huge restriction but if you merge it back say 30cm from the turbo I reckon it will upset the flow a bit. Not trying to say its the main problem but all these little things add up.
the cat is a cheap fix and there IS gains to be had there.
what makes you think it will lean out by unbolting the exhaust from before the cat? id love to know
High backpressure increases reversion, which decreases fuel requirement for a certain load, reduce the backpressure and the fuelling requirement increases.
With an AFM car this increased airflow is compensated, wheras with a map sensored car it isnt.
in theory, yes. but we arent talking half the map worth of load dropping off, if the tune is good it would be lucky to lean out anywhere near whats called dangerous.
plus its only for a squirt, ud want to re dyno it after u fix the problem anyhow.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
