hey guys, im a bit confused on whether or not to use the rb30e pump as well as which oil feed restrictors to go for.
ive gotten a few different opinions and have gotten that the rb30e oil pump is ok as long as i keep it under 7000rpm?
and also the rb25det head should use 1.5mm restrictors x2 on the block. not blocking one off and 1.5 on the other as the oil control guide says.
can anyone confirm?
ive read a shitload of threads and didnt come up with a definite answer.
the rb30e pump can be used but since it has a very small area of contact it is not ideal, the series 2 r33 gtst pump used in conjunction with a crank collar will give a much greater area of contact and should be a more reliable, especially at higher revs.
As for the oil restrictors, that would depend on the oil pump used and the type of vct oil feed if any, that you are doing.. i think if you do the external vct feed or no vct you should block one of and use a 1.5mm restrictor, im doing the internal vct oil feed that uses the oil gallery in the head to supply oil to the vct cam, so im going to try using only a 1.5mm restrictor and see how that goes.. i have also drilled out the oil return holes and running a rear head oil drain kit..
so instead of the stock 2x2mm and 1x1.5mm oil feed to the head ill have 1x2mm and 1x1.5mm
Jarrod
Jarrod
the beauty of not having a large contact area is the inner gear has a thicker 'ring' where the flats are not machined. The saw tooth gear design and the divider inside the pump body makes to less prone to chatter and fracturing the pump gear.
There are a few 8 and 9 second VL's out there using stock pumps.
Edited by DiRTgarage
Is that with any modifications Paul? and is that the rb30e or rb30et pump?
and if i was to use the rb30e oil pump what restrictor setup should i go for if i was going to do the internal oil feed to VCT?
Edited by SECURITY
I can confirm that this is with at least the RB30E as i just pulled my oil pump off there. Jeez its got a small contact area!
Dirtgarage are you saying its superior to run the RB30E pump over an extended collar/rb20/25 oil pump?
ive been looking on the calaisturbo forum and it looks like the rb30et and rb30e Series 2 pumps are fine when doing 25 head conversions as long as there is no wear inside the pump (involves taking it apart and putting it back together) they also suggest shimming up the spring @ the pressure relief valve end.
ill be taking my rb25 series 2 pump off in a few days ill post some pics up of the rb30e and rb25det pumps.. i know the 25 pump flows more at a higher pressure, i think dirt garage is talking about the gears within the pump itself? can you explain it a little more dirt garage... i have heard of a few rb30e oil pump failures with the pump cracking at fairly high revvs
if your going to use the rb30e oil pump i wouldnt restrict the oil feeds
Jarrod
  • 1 month later...
Hey Bud,
I pulled the single 1.5mm and blocked rear off my RB25/30 around a year back as:
1. Since blocking the rear restrictor a very quiet slight thud developed instantly on the first start at the rear of the head for a fraction of a second.
2. there was signs of things getting a little hot i.e not enough oil around to remove the heat.
http://www.lewisengines.com.au/webcontent6.htm
Note the recommended restrictor sizes.
Hydraulic Head (rb20/25/30SOHC) - 2 x 1.3mm Restrictors
Solid Lifter Head (Neo/RB26) - 1 x 1.3mm / 1 x blocked off
  • 5 years later...
Would it be fine to just run 2 X1.5 restrictors if using stock bottom end and neo head with VCT and 90% normal street driving?
I don't understand why if a RB25 uses 2 X 1.5 and its recommend 1 X1.3 and block one off, is this for an extreme high revving engine used on a track?
Why block the front, does oil come thru the VCT and feed the front of the head? What happened with your front cam seal is that related to blocking the front or nothing to do with it?
Because the single feed is all you really need. R33 the VCT does feed some oil into the front cam cap and surrounding area I believe, but that's isn't the case with the neo.
You could run 2x .8mm restrictors for the same amount of flow but I would personally run the biggest single restrictor to minimise the chance of blockage.
Swapped out my front cam seal and haven't seen the car in 6 weeks as I was away with work. Will see if it still leaks when I get back. And it had nothing to do with any oil restrictors, it was a second hand head so I can only really speculate on what caused it but I have a spare cam on its way now so if it still leaks I will swap a new exhaust cam in.
Ok, I don't plan on doing any mods other than these restrictors and I don't wanna use 60weight oil, its a pretty factory setup so far apart from the bigger cubes from the RB30 I wonder if keeping it 2 X 1.5mm like a factory neo would cause issue for the short squirts it will get.....
so many things that people would recommend that it wont have, I guess i'll just see how it goes ...
  • 6 months later...
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
