Hey forum!!! As topic states I need a little help wiring the q45 throttle body to a series 2 rb25det. I already have the grey plug wired to the rb25 tps plug, but I am stumped as what to do with the wires that go to the black box on the side of the throttle body. A tutorial said to integrate into wiring but doesn't state how to. Can someone please explain to me what to do with the three wires that come out of that black sensor? Thanks.
https://www.sau.com.au/forums/topic/308397-q45-throttle-body-install/
There are two plugs on the TPS, one on the flying lead, and the other onthe TPS body.
There are two corresponding plugs on your loom. Simply plug them in. As per the tutorial you will possibly have to cut the loom to make things the right length and tidy things up a bit.
Wow you totally lost me. Let me tell you what I did. So far I have spliced the grey plug off the q45 to the brown plug off the series 2 rb25. Now I need to know what to do with the plug that comes off the black sensor of the q45.
There are a couple of threads around
This one might help
http://www.skylinesaustralia.com/forums/Q4...html&hl=q45
Ok do you see the picture in the link you sent. That grey wire I have wired up already, that part is fine. It is just that little black box that is on the side of the throttle body, I want to know what to do with the wires that come from there. That part I do not get is, the tutorial says to integrate the stock wires into the vq45 plug(with a pic of that black box above it). How do I do that? Can someone just say were to connect the wires of the plug that will be coming from the little black box. The grey plug is all wired up and everything is good with that.
http://www.skylinesaustralia.com/forums/Q45-T-b-t118484.html
That is the link to the tutorial I followed, just need to know what to do with the wires that come from the black sensor.
I asked the question on nico club .com, and I got a response, "you don;t need to worry about that plug. it goes to one of the big white plugs near the ecu that aren't used"
I have had mine Running with only 1 plug connected, it seem to run fine, but After 4 laps on the track, the turbo exhaust housing got way to hot and is now stuffed (warped).
Don't know if it has anything to do with how the TPS is hooked up, but that was the only thing I have changed and the car was fine before. :)
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
