not sure if everyone on here is aware of the No Limits track nights. Its held on the short track under lights, you get heaps of laps and heaps of fun.. They tape a lap timer to your car and noramlly ( when there is enough numbers ) there is a screen with live lap times ( leader board ) so you can see how your going..you also get a print out of your times at the end of the night,
it not uncommon to do 30-35 timed laps in an evening, with each time you out you do 1 warm up lap , 3 timed laps and 1 cooldown lap, so bang for buck its great value..
Anyway these events are stuggling for numbers, and it would be a shame if they stopping them due to lack of support.. check the ( No Limits ) website for info, its easy to join, would be good to see more Skylines out there....
forgot to say this is at Barbagallos
Edited by tricstar
https://www.sau.com.au/forums/topic/308426-no-limits-track-nights/
Also, how keen are you on people new to the track? I'm pretty keen but a bit wary of turning up places where I'm expected to be a driving wizard or something?
They welcome new people. No one is expecting Ayrton Senna to turn up. Half the point of the excercise is to go & learn.
good to see some interest ..... yeah its good bunch of people up there, lots of different types of cars and varying levels of experience.. they have instuctors etc and the guys that know what they are doing, I have found to be very helpfull ....Its held every month, nomally last thursday of every month.....
and its good to see most of the fastest cars are Skylines ( GTR's )
Event is on Thursday,
Be there by 1715 for registration and sign up... Approx $185
CAMS S2 Licence and all other documents will be taken care of on the night...
Note the first night costs are greater as you have to join No Limits itself to get your CAMS Licence.
Very worthwhile guys.....
cheers mike, abit too soon so might give the next one a go, btw is the est $185 inclusive of the cams S2? what do u need to get 1?
sorry but have been here long so dis cams thing is new to me.
To enter most motokhanas, sprint events, hillclimbs etc you need a level 2S cams licence. See www.cams.com.au
To get that licence you need a car club membership (which No Limits can do for you) and to fill out some forms.
No limits can set you up with a temporary licence on the night (If its a once off) or for the year.
The No limits events are a good way to get an instructor in the car with you to help explain how to get around the circuit and also to get a good number of laps in with timing which can otherwise be pretty difficult. Highly recommend them.
you will find all the info you need here. www.nolimitevents.com
Dead keen on coming to the one in March. Would be good if a few other new track people could come to so I'm not the only new one. Been wanting to get into track days for a long time.
So as far as licencing goes, No Limits will take care of it all once you get there? But what's the go with car requirements? Eg, Do you need a cage, fire extinguisher etc...
Guest
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
