not sure if everyone on here is aware of the No Limits track nights. Its held on the short track under lights, you get heaps of laps and heaps of fun.. They tape a lap timer to your car and noramlly ( when there is enough numbers ) there is a screen with live lap times ( leader board ) so you can see how your going..you also get a print out of your times at the end of the night,
it not uncommon to do 30-35 timed laps in an evening, with each time you out you do 1 warm up lap , 3 timed laps and 1 cooldown lap, so bang for buck its great value..
Anyway these events are stuggling for numbers, and it would be a shame if they stopping them due to lack of support.. check the ( No Limits ) website for info, its easy to join, would be good to see more Skylines out there....
forgot to say this is at Barbagallos
Edited by tricstar
https://www.sau.com.au/forums/topic/308426-no-limits-track-nights/
Also, how keen are you on people new to the track? I'm pretty keen but a bit wary of turning up places where I'm expected to be a driving wizard or something?
They welcome new people. No one is expecting Ayrton Senna to turn up. Half the point of the excercise is to go & learn.
good to see some interest ..... yeah its good bunch of people up there, lots of different types of cars and varying levels of experience.. they have instuctors etc and the guys that know what they are doing, I have found to be very helpfull ....Its held every month, nomally last thursday of every month.....
and its good to see most of the fastest cars are Skylines ( GTR's )
Event is on Thursday,
Be there by 1715 for registration and sign up... Approx $185
CAMS S2 Licence and all other documents will be taken care of on the night...
Note the first night costs are greater as you have to join No Limits itself to get your CAMS Licence.
Very worthwhile guys.....
cheers mike, abit too soon so might give the next one a go, btw is the est $185 inclusive of the cams S2? what do u need to get 1?
sorry but have been here long so dis cams thing is new to me.
To enter most motokhanas, sprint events, hillclimbs etc you need a level 2S cams licence. See www.cams.com.au
To get that licence you need a car club membership (which No Limits can do for you) and to fill out some forms.
No limits can set you up with a temporary licence on the night (If its a once off) or for the year.
The No limits events are a good way to get an instructor in the car with you to help explain how to get around the circuit and also to get a good number of laps in with timing which can otherwise be pretty difficult. Highly recommend them.
you will find all the info you need here. www.nolimitevents.com
Dead keen on coming to the one in March. Would be good if a few other new track people could come to so I'm not the only new one. Been wanting to get into track days for a long time.
So as far as licencing goes, No Limits will take care of it all once you get there? But what's the go with car requirements? Eg, Do you need a cage, fire extinguisher etc...
    • R32 HICAS, so long as the CU is not itself faulty, is easy to keep working enough for the PS. Just unplug the smaller of the two loom plugs, on the CU, like I have already said about 4000 times on this forum. This works with all the stock hardware, or with a lock bar, or with a complete removal. I know, because I have done all of them. OK, actually, I never put a lock bar on because why would you put a lock bar on when you can get rid of the whole lot, including the stupid tie rod ends?
    • Join the NorCal facebook group btw, but if you can confirm it is HICAS I would install a lock bar and do the work to keep the HICAS control unit happy despite the hardware not functioning. The HICAS control unit is also responsible for speed sensitive power steering so if it's unhappy you'll get failsafe/heavy power steering. A standalone can control that power steering solenoid valve but sometimes it's just easier to stick with the factory setup. Tomei makes a little electronic module that you can install to fool the control unit. I would probably go through the effort to not use a scotch-lok and build a harness so I don't have to chop up the OEM harness. Where you could source those connectors and pins I wouldn't know at the moment though.
    • Oh, another question comes to mind though. What sort of shitty fuel are you feeding it. Mine, a turbo, has to be fed 98RON, so it doesn't ping itself to death. 98 in Oz is good, dense fuel with minimal oxygenated compounds. Meaning that the energy density is high, and if the O2 trim is working, you will get more MPG than with a lesser fuel. If you're using some sort of piss poor E10 blend with some other MBTE or other oxygenated additions, that could explain using more per mile.
    • I have no idea where the thump is coming from, it sounds like its from behind me but im not exactly sure. And it was the HICAS light that came on.   I think a complete delete is the route im going to go. Probably going to pick up the kit within the next month and get it installed. HICAS is just going to end up being a headache if I keep it.    Thanks you.
    • Just putting this here for reference for other beginners. Similar to what I said above.  I learnt if you have a few dents that are fairly close to each other (within a couple of inches maybe 2-4 inches?) Use filler across them all and sand it all at once with the long block as opposed to fixing them seperately.  Will make life MUCH easier because you won't get stuck in the cycle that I did. I think doing it seperately there is some overlap (mean your whole repair zone might cover near the area of the other dent) and you start sanding near the other dent making a low spot.
