Price $22,000.00 ONO
130,100Ks
Has had 100,000k service done
Silver in colour
Nismo Aero body kit
Mods
Tein Aus spec super street coil overs
Garrett GT 3076r .82 external gate
external oil cooler
3" turbo back exhaust
Tomei Fuel Pump
Front mount intercooler Custom stainless piping
Gizzmo MS-IBC electronic boost controller
Innovate Wideband installed
Nistune ECU
Nismo 480cc injectors
Nissan Z32 AFM
18" rims and tyres (235/40r18 front ,265/35r18 rears)
Brakes just been redone
regularly serviced
MV Automatics stage 2 Shift kit installed
Has done 248kws with old housing
Comes with Safety Certificate and rego until June
This is a very tidy car and drives very well
Contact Via PM
Edited by Haines
https://www.sau.com.au/forums/topic/308556-r34-gtt-1999-2-door/
  • 1 month later...
  • 2 months later...
  • 1 month later...
hey, i just want to know what do you mean by ""MV Automatics stage 2 Shift kit installed"" Do you mean only the valve body from MV Auto??? only because I see that you have a tiptronic. I have a tiptronic, i wanted to put in a full shift kit to manualise my car, and he told me that it cant be done because it already has tiptronic, so only the valve body can go in... so whats yours???
I believe full manual would make it stage three if anything
I come from the old school V8 days and from memory thats a stage 3
stage 2 is just the valve body ,harder firmer shifts
And Phil I'd love for it to sell soon
Edited by Haines
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
