sorry guys only just got internet access...
the small crack in the block that was repaired last time engine was freshened has opened up weeping coolant out. In the interests of my own and others safety i decided not to run the car. Looking back i probably should have grouted the block as the crack is below the bottom of the welsh plugs and grouting would have stopped it.
Its very strange as when the car was rolled back on Friday no coolant was leaking out of it. A little later i jacked the front of the car up in preparation for welding a lambda sensor bung at the base of the dump pipe and coolant started to drip from the rear of the engine. We stripped the engine on Friday night and tried to repair it but on Saturday morning started leaking again. Engine is now out and ill decide tomorrow if ill just grout it or replace the block with a fresh one.
Very disapointing for all involved with the car.
As u said paul, last thing u want to do is bin it down the track with coolant on the back wheels @ 150mph.
Safety first :unsure:
  • Replies 66
paul explained to me that the crack was repaired 5yrs ago...maybe from all of the strain the engine has undergone caused the crack to weep?
yeah have known about the crack for quite some time...has been pretty good up till now. Most 05U blocks will open up when subjected to this power level for a long period. All the bogged launches twisting and stressing the block would have done it no favours.
I grouted it this afternoon...no more weeping coolant. Was going to machine up another block but didn't want to crack a good one. Engine back in by the end of the week.
Sorry to hear about the bad news Paul, hope you get it all sorted this time mate.
In your experience, for block strength is it ok to grout as far as the welsch plugs and still use the engine for circuit work? Any coolant issues?
i would not recommend it. bottom of the welsch pluds as a maximum. but run extra piston to bore clearance.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
