So ive got my wideband controller working on the bench, time to hook it up to the car and get some data logging done.
The wideband controller has various inputs for speed, rpm etc... all from the ecu.
What I would like to know is, what is the best way to tap into the ecu to get the signal? Im fearing the only way I have is to cut and re solder the wire harness as it comes out of the ECU.
https://www.sau.com.au/forums/topic/308608-best-way-to-tap-into-ecu-wires/
STOP!!!! Dont cut the wires, just strip some of the coating off them and splice the wires you wish to tap in around the bare ecu wires and solder them together and
tape it up with some good quality electrical tape.
Picture care of evilution.co.uk
Picture care of legacygarage.com
Hope that helps. :thumbsup:
99 GTT, perfect, actually dont know why I didnt think of that its so obvious...
errno, i've seen those before, but im a bit skeptical, what if they cut in too deep, id worry about the wire breaking over time.
Thanks guys, off to do some soldering tomorrow and hopefully logging some AFRs
Edited by ascenion24
These join every phone line cable in NSW, look inside those cylindrical junction boxes and you will see hundreds of them, Ive used them on and of for the last 20 yrs and had no problems.
if they cut only the insulation then there not making contact with the copper, so they must come into contact and therefor cut the copper wire to some degree.
Im guessing you'd have to know the thickness of your insulation to get the right size of those joiny thingos... seems to much of a pain in the ass considering the consequences could be no connection or cut wire.
http://www.takakaira.co.jp/Main.aspx
Field one touch connector FTW!!!!!!!!
Not a cheap option but undoubtedly the BEST way
combined with the strip an solder method I think
If only temporary though Solder a bit of solid wire to ya leads
an push into the back of the plug
Edited by noone
a while ago i thought i'd give those little clip things a go, to install a SAFC on my old 32. driving up the motorway one day and the unit just died, hence my car died. not fun at 100kph. it was that little clip splicer thing that wasn't giving a good connection, and yes i did use the correct sized one for the cable i was splicing. i wouldn't recommend them to anyone.
what i like to do is cut the wire. strip the ends. slide a piece of heatshrink down the wire. solder it back up. slide the heatshrink over the join and shrink it down. you cant go wrong if you solder a wire properly.
Put your credit card against your leg, is it touching your leg, has it cut your leg.
Do you use M8 bolts to go onto a M6 nut, of course not, you use the correct size.
Ive connected up my shift light recently in 20 seconds, that included wrapping the connection in insulation tape, and, there is no drop in volts from the ECU to the light.
Ive used these for 20 odd years and if you do the job correctly you wont have any problems.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
