i dont imagine they would be much different to 33 gtst item. Have u checked with just jap. They supplied my jjr dump/front pipe for 33. Perhaps exhaust side of 34 turbo is different and exhaust route on 34 is different in which case the pipes may be quiet different.
I got mine from BOS Importing but his website is down.
I think It's branded m performance or something.
I'll have a look for you later :ermm:
that would be great because everyone i find says in brackets (not for r34)
My understanding is the dump pipe is the same across models, its just the front pipe that is different. So if the dump pipe and front pipe is merged into a 1 piece item then yes the R34 GTT one will be different.
I just bought one of these for my R34GTT, it says R32, R33 and R34 and I made sure with the seller. Although I havent tried to fit it up yet.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWNX:IT
See how this dump pipe says any model R32, R33 or R34:
http://www.justjap.com/store/product.php?p...=276&page=1
Whereas the 1 piece dump pipe and front pipe combined has different part numbers for 33 and 34:
This is another one on ebay that says it fits R32, R33 and R34 (again it is just the dump pipe):
http://cgi.ebay.com.au/NEW-EXHAUST-TURBO-D...=item5632103958
But this dump pipe says it wont fit both R33 and R34 like you said:
http://www.gktech.com.au/front.asp?pid=11&...uctID=RBXX-DUMP
So I am confused, but I think I trust just jap the most.
Hope this helps or prob just adds to the confusion!
Edited by Harey
The CES one is a 1 piece item that covers both the dump pipe and front pipe. Again it says different part numbers for R33 and R34 which is expected:
http://www.cesracing.com.au/products_2.htm
Although it is quite pricey!
My opinion is these dumps only fit up to the standard exhaust housing so I dont think its worth getting a super dooper one. If you are serious you wont be using the standard exhaust housing anyway.
Agreed with my exhaust all i need is a dump pipe as have the rest of the exhaust and as i am keeping the standard turbo there's no reason for me to go real expensive on the dump/front pipe. If i was getting serious i would be going a high mount turbo setup in which case the dump i buy now is gonna be useless.
Harey when you get that dump pipe from ebay could you send me pictures of it particularly photos of the inlet/outlets looking inside if their ok i might just get one of them although would prefer mild steel for the dump.
just my luck i found one but its little out of my price range
http://cgi.ebay.com.au/NISSAN-SKYLINE-R34-...=item4ceda1ab17
but its exactly what i would want
Not sure why but that looks really weird. I would get the justjap bellmouth stlye one for $180-200au. The difference between bellmouth style and split will be bugger all on a standard turbo.
Edited by Harey
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
    • I spotted a black C34 in Mittagong this morning!
