After a lengthy search for the right paint I finally found what I was looking for, and it looks great!
So this weekend I decided to take of the wheels and get it done over the 2 days to allow time for it to dry properly.
Products used:
Duplicolor Metalcast Ground Coat - Metalic Grey.
Duplicolor Metalcast Paint Color - Metalic Red.
Heat resistant clear coat.
Before i Started I took some pics so I could do a flashy before/after shot :D and here goes!
post-67625-1266646988_thumb.jpg post-67625-1266647212_thumb.jpg post-67625-1266647342_thumb.jpg post-67625-1266647382_thumb.jpg
After taking a few pics I unpacked my new slotted brake disc's, gave them a clean and let them dry.
First I did 2 layers of the ground coat - dry for 30 mins - then 2 layers of the red.
They look amazing in different lights, from a deep ruby red in the dark to a vibrant candy red in the sun.... love it!
Following pics dont really show much as they were taken indoors with shit light.
To remove over spray I cut back the paint with a razor.
Forgive me on the file size of all these pics :down: , i'll use smaller ones next time.
when i start on the calipers i'll add more pics.
https://www.sau.com.au/forums/topic/308971-diy-brake-paint-job/
More shots of the painted Calipers:
Dude... they're the brake discs and why did you paint them lol?
I would have been going a gold or red on the calipers but wouldn't have been touching the discs...
why bother painting so much of the rotor then? why not simply cut a hole in a piece of newspaper the size of the hub and save yourself a heap of time?
and you gotta love how a set of 20" rims make decent size brakes look like you have brakes off a barina.
Nice Color.
So you masked up the rotor face when you painted then??? Sounds like a nightmare if you didn't and plan on rubbing it back to remove the paint. Or... Maybe i'm just confused at how your going about this. Look forward to seeing the next round of photos to clarify how your going to finish this off.
For those who don't trust my retard ways :down: more pics:
Basically I was always going to end up with alot of over spray because im putting color into the slots, so once its dry all i do is razor off the unwanted paint and fix up the edges, use sand paper to remove stubborn paint.
Edited by EnRag3D
The brakes will 'self clean' as it were; the pads will just strip the paint off the rotor and leave it shiny again.
Seems a bit of a waste of time and effort though, may as well mask up the rotors as alluded to.
Edited by Tony de Wonderful
er ok that makes more sense.
Still I can't see the paint hanging around in the slots for too long, especially if you track it, the rotors can get red hot and the paint will blister and then flake off.
If you want to be an ultra-geek you are probably hurting the cooling effect of the slots by adding paint.
Now for the finished calipers, crap photos atm as its overcast :D
Also a few ppl have mentioned to do the disc in a gloss black, I agree with you on that one but I will see how this turns out. It's not too hard to remove paint from disc's anyways so im not too fussed about them at this point.
Also I would love some tips on what I should do with the "Nissan" stand out text on the calipers.... Leave red / Paint white / sand down?
Any ideas appreciated!
I'd just use a file to get most of the paint off then finish it off with some sand paper so it's just the bare metal showing. I wouldn't bother about painting but if you wanted to, you could try buying a white 'paint marker' and carefully running over the Nissan logo with that. I've never used one though.
You probably should have masked up the rubber seals too.
Edited by -Jimmy-
Arrrhhh. That looks much better now the rotor is shiny again. lol. You had me worried.
As for the logo. When I painted mine I just hit the logo with a file to remove the paint of the writing. Came up well.
Need to redo mine soon though. Looking worse for wear.
yeh theres a few changes I need to make, will be doing it a bit different next time round on the front, also have decided to do the brake disc in a gloss black.
I wish the back caliper wasent half the size of the front one - doesent really show off the red as much as :thumbsup: .
Edited by EnRag3D
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
