Just put a hypergear atr28g4 ig on the stock manifold with vband dump with extra bung for a techegde wideband. I do suspect the dump is leaking alittle at the vband clamp. It sounds fine while idling. I can plug in a mates motec PLM in the tail end and check it.
check how hot the wideband cabling is getting. i had an issue once with my techedge unit giving lean values, turned out the wiring was suffering from heat soak. but this was only happening after about 10-15min of driving once everything had warmed up.
Wideband cable shouldn't be the problem it dosn't appear to be getting hot. I will check out an exhaust leak being the problem. Does anybody use exhaust joiner paste when connecting turbo and dump via vband?
  • 3 weeks later...
Yeah i did do the calibration, I might do it again. I did do 1 stupid thing tho i had the wideband sensor pluged into the exhaust for alittle while while i was first sorting the bugs in my new system, but it was not wired up. Would this kill the sensor?
So basically the calibration was done on a dirty sensor
Calibration changed nothing. it wont be the sensor the cruize afr sit in the 14's perfectly fine any ideas?
I have checked for vacume leaks with a can of carbie cleaner and no change to idle.
Would a stuffed altinator cause the fuel pump\injectors to flow less? i did notice when i pluged in nistune that to voltage level is barely hitting 12v?
aslo sometime the wideband unit starts flickering to its heat cycle meaning not eough voltage to keep it hot
If the O2 sensor is working and the ECU is going into closed loop then look at the fueling, a blocked fuel filter will lean out mixtures as the fuel pressure in the rail will be lower.
Just out of interest does the techedge O2 sensor have a narrowband output signal?
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
