Hi everyone!
For sale I have the following parts located in Sydney
RIPS Plenum to suit RB25: I never actually fitted this to any of my cars while they were running but it is in good condition and the intake flanges matches the rb25 gasket. I am unsure if there is a difference between NA and Turbo manifolds. I have a spare throttle body here too which came with it you can have
$450 SOLD
R33 Strut tower bar
$50
RB26 Cam covers and valley cover in QM1 white
$300
RB26 Front timing cover in black- Have 2
$50
Z32 AFM and plug
$SOLD
Nismo 750cc injectors for rb25 on rail
$SOLD
Genuine Greddy intercooler kit inc alloy piping and cooler, cold side pipe has trust style BOV
$400
Apexi Power fc for r33 GTST with hand controller
$SOLD
R33 GTR turbos with standard dumps- taken off the new motor I bought for my race car. approx 60 000kms of standard boost
$500
Standard coilpacks from the r33 GTR motor
$50
Twin Turbo pipe for RB26x 2 sets
$SOLD
RB26 exhaust manifolds
$150
Just Jap Rear camber arms- brand new never fitted
$160 pics further down
Oil cooler kit
$100
More parts and pics if you scroll down
some pics:
Power FC for R33 GTST with hand controller
Z32 and plug
Nismo injectors on rb25det rail
all the mods were done around 10 000km ago so egverything is in top condition I need to degrease the fuel rail but thats about it.
located in glenfield in sydney.
here are some pics of the 26 timing cover, i have 2 for sale
also the remaining twin turbo pipes and rb26 manifolds
some brand new just jap r33/S14 rear camber arms $150
Just jap oil cooler kit $SOLD
Factory 32 GTR intercooler rubber pipesx4- $50
Pipe to shorten intake piping and get it out of the way for a nice turbo setup $40
note it is currently painted silver.
more stuff to come keep checking back
I will get some pics when its not raining, the cooler is still on the car atm, i have to take the greddy plenum off to put the factory cooler on, and i'm not able to pull it off til next weekend unless someone wants it urgently.
It is a spec m kit i bought brand new, with a bov installed on the hot side under the guard. I have had it for a few years but the car has only done 10 000 k's.
does have a tps on it which plugs straight in. I'll take a pic of the throttle body on the weekend im not sure which type it is. Just came with the plenum lol but it is a nissan part
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
