  • 4 weeks later...
  • Replies 234
Posted Images
you dont NEED them to run the device, but if you want those two thing monitored then youll need the sensors too.
the rest of the stuff is taken from teh ECU. to have exact water temp there all the time, IMO its well worth its money. dont want to overheat in these summer temps. there are only limited spare VQ25DETs
Question guys - I'm thinking of getting one of these. Will I need the Boost sensor as well as the oil temp sensor too?
I'll be running both of these on mine in the next little while, mainly so I don't have to run a separate boost gauge; keeps everything neat.
I'll be using the oil temp probe in the gearbox to monitor auto temp :thumbsup:
You could run two sensors and switch between them... If the sensors weren't $200 each I would have that one also. For the oil temp and oil pressure you will need an oil filter adapter or oil cooler kit like the Greddy one that has threads for the sensors.
What do you have to do to have the Power (PS) display functioning? I've put in the vehicle type (Nissan), body type (wagon), weight (1800kg), am I missing something?
Apparently my car produces Zero power :rolleyes: . Everything else I've displayed so far appears to work except this one, rather curious.
Any help would be great :thumbsup:
You need to include motor size
weight - 1,800kg's
motor - 2.5lt
type - swagon
driver - Awesommmmmmeeee!!!!!
didn't know about the gear ratio's....what are our's again?
Yeah, I did all that when I set it up originally, not sure why it's not playing the game. Maybe I'll just go through it again
Driver; well that's a given; right?:cheers:
Where do you alter the gear ratio's? Is that in the "offset" bit?
Thanks guys.
i cant remember, i just followed what the book says, it says to input your speed at a certain amount of rev in each gear. i dont know what its called i just called it gear ratioteehee.gif
Ok, I'll have to have a read...
  • 4 weeks later...
I have a new stock radiator and thermostat as well as a 1st generation Informeter.
Unless I'm really pushing it the temp sits at 90c in summer.
Hume highway from Picton to Moss Vale at 120ish up the hills on a 30+ day might get to 94c.
Pushing up twisty hills in the RNP produces similar results.
A more general Informeter question....
I've got the airbag light flashing at the moment, but the diagnostic code readout on the Informeter is reading '0'
Anyone know if it's possible to get the codes to display?
Or is it a case of the cars different ECU's not talking to each other and the Informeter can only display codes from the engine management?
Id try the error code readout sequence (wait 3, accelerator pump etc etc) , that may give you code for the error - but I was never able to get a code for why mine was flashing. Ive recently connected one of the seat sensors to the passenger side (drivers side has a resistor in place of the sensor) and performed the reset sequence. Seems to be holding.
Id check you have the plugs under your seat if you've always had the light flashing!
Not the informeter, there is no input for it. I do all my logging with the Emanage Ultimate, wideband included, then I send the log to my tuner who rings me back and tells me if I need a re-tune after each mod. lol.
    • As Duncan mentioned it's likely a remapped ECU, like the the one listed in the link I post earlier:  https://minkara.carview.co.jp/userid/444260/car/444612/2099320/parts.aspx He quoted 444PS with an unopened engine and twin GT2510s @ 1.1bar boost... sounds about right?
    • That’s great to know. I spent some time looking for info last night but had a hard time finding anything relevant
    • Ah ok the turbos looked standard when I had a look at the car. Didn’t look it was ever removed but very hard to tell. These are the best photos I have if it helps identify anything.    I know it’s basically impossible to see anything 😅
    • Its only a guess, but it likely doesn't have cams; probably a Z32 Air Flow Meter and slightly larger turbos. It was very common to chip and remap the standard ECU back in those days, but it means you won't be able to modify it further without replacing the ECU
    • Amazing! Thanks for sending this through. Feel safer knowing a reputable shop worked on the car before I decide to purchase.    Do you know much about how they would have tuned their cars through chips?    From what I know, the car sounds like it has very small cams, the usual exhaust and air filter mods and a chip in the stock ecu. Motor sounds healthy and starts right up with no hiccups or smoke, compression is around 140-145 cold (wasn’t able to test this while it was warm)
