hey guys i own a 1990 cefiro with engine mods as follows:
rebuilt rb20det
worked head front facing plenum
fairlady t/b (unsure what model)
high mount mitsubishi td06-19c (part no on front 4917952000)
z32 AFM
huge coola of unknown brand
3inch exhaust
high flow bosch pump
rising rate reg (some chinese shit brand)
mines ECU
ATM im not driving the car atleast untill iam confident its happy,
besides that its ready to drift i have upgraded suspension, brakes, bushes , 2 way diff, 25 gearbox ,clutch
i just need to fix these few problems
while iam good with suspension , brakes and bolt on mods i dont know sfa about engine internals except noise is bad hahaha
ok so heres the questions;
1) iam getting a rattling from the engine over about 3000rpm she drives fine very smooth, i thought it was coola piping on the engine bay but nothings loose or moving
what signs would point to knocking detonation or engine damage? (last thing i need with a rebuilt motor)
2) how much power could this turbo produce ? (when all is proven safe)
3)i have very heavy steering i have checked for leaks and topped up fluid and the belts tight im wondering could it be the pump how would i tell?
4) whats the mines computer like is it worth keeping or should i get a stocky with a remap?
5) it looks stock and sits quiet high .... but will front coileys stop me from getting RWC in QLD (i put stockys in the back already for RWC but i dont have stock front struts)
6) does anyone know a reliable TRUSTWORTHY mechanic on the gold coast
thanks for reading
cheers ..Ben
https://www.sau.com.au/forums/topic/309657-my-love-for-rbs-has-been-rekindled/
cud be the pod rattling on the body once higher rpm's make it vibrate more. put some cloth tape around whatever it is on with the body and see if you can hear it as i had the same thing
also high intake temps result in detonation so keep an eye on that. u can use the stock ecu water temp sensor off an rb20 and thread a hole in your cooler piping if you wanna keep track and just hook it up to a water temp guage.
Edited by Dan_J
far as i remember there was a thread on here about rb26 intake temps as they have a stock intake sensor and average was 45c. no idea on dangerous but at a guess 55+
just make sure its the ecu sensor not the one that goes to the cluster.
the rb30 may run an ecu sensor aswell so give that a try if you can see it with the same colour/mark wire on the sensor as well as on the loom next to the plug on the ecu.
Edited by Dan_J
. the ecu water sensor has 2 wires coming from it, one is a ground or positive and the other is the sensor
a aftermarket gauge has 3 terminals, power + , - (ground), sensor. T off at your cig lighter for +/- powers buy just scratching the plastic with scissors or a knife that isn't that sharp and wrap your connection around there and tape it up
Edited by Dan_J
ok so from the sensor run one wire to the cig lighter for ( + ) power one to the gauge (sensor) then run the ( - ) negative from the cig lighter to the gauge also ... is this correct prob sounds basic to everyone else but just wanna be clear before i start blowing fuses
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
