Series 1 engine loom and ignitor sold.
both fan shrouds sold
alarm sold
ecu sold
gearbox sold
pivot boost guage and shift light sold
heaps and heaps of good 33 stuff still here let me know what you need.
  • Replies 45
Noel, kinda related, but have you got any front rotors laying around? (don't want to break up your complete brake package)
No sorry Dan. Just the complete front and rear kits mate.
hey bud, wat colour would the car be?
And are you from Ipswich? I think i bought a front bar off you a while back...
Car is gun metal grey and yes, that was me.
still got the headlights? what nick are they in? any pics?
headlights are sold
Are you selling the driveshaft?
If you are referring to the tailshaft it is sold.
  • 6 months later...
hey noel,
thanks for the loom, just double check the loom is for a turbo 25, as nissan are saying from their computers it is GTS25... do you know if there is any difference between the de loom & det loom
thanks again
Tyron
hey noel,
thanks again
Tyron
to the best of my knowledge the loom should be fine mate. Iif it isnt just give me a call.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
