RB heads flow pretty darn well off the boat but I have only ever had one good experience with a head work company and that was Unlimited Headjobs in Sydney. Can't remember if it was in Leichardt or whether i'm imagining it. NO-ONE in Wollongong.
Adrian
Thanks Adrian,
I'll try a find a number for them, you don't know how much they charge for a port and polish do you?
Do you think it is worth the money to get done, or will the gain be pretty minimal. As there's a company that usually advertise is zoom, that say gains can be made of up to 40% on turbo engines, however if I can only get a 5% gain it might not be worth it.
Cheers, Ryan
If you are going full house and chasing that last bit then yes I would p/p.
Remember that a turbo engine pushes the gases in , it doesn't rely on vacuum or atmosphere to get the fuel/air charge in.
Upping the boost by 1lb would probably have the same result on a good flowing head ( which the RB25 is reasonable).
If you could do the job yourself , fine but I think a good 3 angle valve job and a cleanup will be fine.
Cheers
Ken
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
