Hey people,
SAU-NSW is having our first Dyno Day of the year this weekend, starting at around 3pm and going into the night. The dyno there is only a 2WD one, but if you're bringing a Stagea, R33 GTR or GTS4, or R34 GTR or GT4, then drop your front driveshaft and come and have a run!
The venue is Unigroup Engineering, the address is Unit 17 of 17a Amax Avenue, Girraween. (Amax Avenue is parallel to the Great Western Highway, and the workshop is less than 5mins from the highway itself.) Best access to Amax Avenue is via Girraween Road (where the big Caltex Servo is, then turn first left into Amax), or via Toongabbie Road (where there's a set of lights and Fox Hills Golf Club, then turn first right into Amax).
http://maps.google.com.au/maps/place?cid=1...UYUUCn43qSDc-mg
You can get more details from the link in my signature.
Come along, even if it's just for a look and a chat to fellow SAU members.
https://www.sau.com.au/forums/topic/310190-dyno-day-this-saturday-6th-of-march/
I would be interested Nick if you did this in 4wd dyno.
Too hard to disconnect the front end of a M35 to consider doing it.
Cheers
Andy
How hard is it Andy? I have to drop them for a run next week mate, haven't had a look yet. Big job?
Craig, are you just going to keep dropping hints, or are you going to post copious amounts of pics and vids soon.
I would love to come up for a drive and run but unfortunately I am busy this weekend fitting my new Denso 570cc injectors. :)
hard enough that no one has posed up yet how to do it and I am certainly not that keen to be lying under my car for an hour to do it.
I would rather know the 4 dyno number anyway.
If the CV joint boot arrives on time, I'll most likely be changing that on Friday with the help of the old man, and I might use that chance to remove the driveshaft as well...
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
