  • Replies 129
^ looks fine to me.. You did well for your first time. Bet your addicted now??
Ian - just ring flash right? Will be great for portraits. Sorry dont have any setup up shots :) Will take them next time.. Oh and it wasnt my studio btw.
My first proper photoshoot. Not 100% happy with all the photos, but its a good learning curve smile.gif
I think did you well dude.. Just keep practicing and pushing yourself.
Edited by siddr20
Yeah keen to try some more for sure with the 5D2. I walked all the way up there and f**king forgot my tripod! Can you stitch the panos in photoshop or is there a good 3rd party program to use?
a dodgy program to use is Windows Live ... some thing some thing.. have to check what it's called when I get home. but it has a program that does it, but because it's automated it doesnt turn out that great
Hey Ian, got any other test shots with it?
So it uses the standard flash on the body to light up?
Not yet but i've just replied to a PM on Facebook from a young lady that wants photos done so if she agrees she'll be the guinea p!g. :D
Zennon i'll be primarily be using for portraits but may use it occasionally for macro. :)
Shot a few photos in Sydney a few nights ago...
Thanks Sidd. My parents bought me a photography coarse for my birthday, so I'll pick up a fair bit from that in April. So I'll keep practising and posting up the shots as I go along.
James, I use a Cannon 1000D which is in my mind the best beginners DSLR for the price. But for someone who has owned 7 cars, including a GTS, GTS4, 2 GTRs, BMW, Audi, and now a Porche all before their 18th birthday, pretty sure you can afford one of these cameras :D They're the cheap parts... Next cruise I can show you around the camera if you want. Obviously I'm no where near as good as Ian, Sidd, Sam and Zennon (Although I do aspire to have their skills one day), but I'm getting the hang of it. :D
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
