Alright those unfortunate to have heard this noise before come and confirm what I think I have diagnosed.
A few months back my rb26 started making a bit of a ticking noise at startup, that would trail off after about a second (read oil getting to said spun big end bearing).
It also started making the same noise between about 2500 and 3500. Power seemed fine, thought it was a loose belt or something.
I have been trying to get it ready for the track so have spent a bit of time investigating. Today I pulled the wire off coil 6 and it seems the noise has gone away. Car was warm by the time I had played around with it so going to wait until tomorrow morning and start it again, see if the noise is still gone.
I heard a pretty good explanation of the actual sound the other day - like when you sit a playing card in the spokes of a push bike - pretty close to that.
So - does it sound like a spun bearing to you?
https://www.sau.com.au/forums/topic/310386-spun-big-end-bearing/
  • Replies 44
not really....and I've heard a few.
does it get louder with revs going up and quieter with revs going down?
in any case if you think its got a bearing spun you should not be running it more than a few seconds, the longer you run it the more shit gets through the motor
its very possible. check youtube for other spun bearings and compare to yours.
try avoid running it much more. get the sump off and replace the bearings. you might be lucky that it hasnt damaged the vrank yet. and might be just a quick r+r.
Hmm well I would definitely love to be wrong. It has been running like this for months - probably a good few thousand kms.
Duncan - it does get louder from 2500 to 3500 but then the noise seems to go away.
Dave - I did grab each injector while it was running and #6 didn't seem any different - but I will investigate further - I guess disconnecting #6 injector wont really help me any further with my diagnosis - would need to move it to another cylinder. Of course I threw out my old R32 injectors over the weekend - some of them were leaking but could have come up with at least one good one.
oh yeah should have said....it sounds like a gnome hammering on your crank...not a card in the spokes :)
if you want to be sure and have no rush you could get the oil analysed, will tell you for sure if you have a bearing issue
Yeah its funny how it does it for about 1 second when first start dead cold only. This is what lead me to believe it was a bearing as the oil would have all drained out.
Its not like a normal injector ticking noise - its quite audible within the cabin, quite metalic sounding.
RE: Lifter noise - forgive my ignorance but the rb26 being a bucket and shim valve setup - are there any lifters??
theres no lifters, but there can be excessive clearance in the shims, but its constant,
just start getting some prices together, you have to pull the motor out either way by the sounds of it, now the debate whether you get a 2nd handy or fix your current motor with the option of a rebuild
I just went out and had another listen - it really isn't like any of the others I looked up on youtube. They are all BANG BANG BANG BANG, this is nowhere near as loud.
Will have a play with the injectors tomorrow - this was my initial guess.
Duncan - who does oil analysing up your way?
Got a bit of a quote from Racepace a while back before Ben sold up - $15k for the whole shabang N1 block, 33 crank etc etc out and back in - wonder if Chris has adjusted the price structure!! End of the day this is going to be the best route - was going to do it eventually but thought I may as well have a bit of fun with this mill until the inevitable happened.
sorry to be the one to disagree, but your description is spot on to every big end ive ever heard.
now if people are nit picking to a spun bearing vs a worn bearing i dont know, but card in the spokes and your description of 2500 to 3500 is exactly consistant to the many bearings ive heard.
thats the sound of an early days big ender, for all you know, it could still be savable.... best bet, drop the sump and check number 6 :)
im 100% sure noone will agree with me here, but I have actually had success in the past where this has happened to the extent yours has, we have isolated the cylinder like you have, and matched a new bearing to it without machining and the motor lived on forever more.
so GL
I had a 180sx which had a light taping noise very much like you are describing after lots of looking and listening I eventually did a compression test and found it was cracked ring lands on the rear cylinder. It was hardly noticable aside from a slight drop in boost and the idle was a tiny bit rough- just a smidge.
I hope it isn't that in your case-good luck with it.
Cheers.
Cheers Scott - yeah I have read in my research of people with a similar sound running for a few months without a problem until they fail properly, problem ending up being a big end bearing.
Wont bother starting it again and get it to someone that knows that they are doing!
I wish it was an easy exercise to drop the sump on a 26 - have never attempted it myself but I think regardless its an engine out.
Before you do anything drastic pull the oil filter off and open it up with a tin opener or chisel and look for bearing materials -little specs of copper coloured material. Next I would do comp and leak down check to make sure you havnt delaminated a piston crown. If all is healthy then it may have shrunk a skirt - but it's not a common problem on these engines.
From this section of your original post:
"Today I pulled the wire off coil 6 and it seems the noise has gone away"
The noise would be constant - It wouldn't go away if you pulled coil no 6. Your crank will spin regardless of the coil being attached its one piece, hence the noise should still be there.
I would imagine a big end would give up or at least get worse once it lets go, that fact you have driven thousands of k's since indicates the problem is not a big end...
Just some fuel for the fire...
Yeah I guess the theory is if the cylinder isnt firing it isnt going to be loading up on the crank, less loading on the bad bearing and so less noise.
I gave it another kick in the pants this morning from dead cold, with no 6 coil disconnected and it still made the noise although somewhat more muffled. Going to try disconnecting the #6 injector tonight from dead cold and see how I go.
God I really do hope its just an injector dying - the one on #6 was actually flowing a little higher than the other 5 in cleaning/testing before I put them in. #6 plug is perfect however, no leaning or fouling.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
